This is perhaps where it starts to get tricky!
The next step is to drill in the end of the axle with a 2mm dia. drill. The aim is to drill deep enough that the end of the drilled hole is between the cheeks of the crank. The position of the end of the hole then needs cross drilling in a convenient size - I used the first drill I laid my hands on, which was 0.7mm dia. The 2mm dia. hole will then take a short length of 2mm GRP rod, which will later form the core of the insulation in the axle. This picture shows the depth of the hole drilled, by the permanent pen mark on the rod. You'll note that at this stage the rods are over-length and that the ends of the rods have been shaped to make them easy to insert:
The two rods are then cut off to length, this is roughly 3mm shorter than the depth of the 2mm dia hole. As you can see, the rods are prepared individually so need marking for which end of the axle they go in. No permanent pen on the rods when ready to install, previous experience has demonstrated that permanent pen ink and epoxy adhesives are not best buddies!
The rods can then be keyed up with an old file before mixing a quantity (don't skimp!) of DevCon 2-ton, which is then wodged into the ends of the axle, the GRP rods are then smeared in the epoxy and stuffed in to the drilled holes each end with a cocktail stick. As you do this, excess glue will squirt out of the 0.7mm hole. I managed to do both at the same time and then left the axle with the two 0.7mm holes uppermost for the adhesive to cure.
With the adhesive now through initial cure, I thought I'd show you how this crank axle would fit into a 'normal' finescale chassis. This is the one from the G6 before its imminent disassembly and you can see that with some suitably thinned bearings there's no problem getting it to fit. In fact, in finescale, it can often be the area around the slidebars that ends up as the pinch point, but I guess that's a digression...
I'm off for another rummage through the G6 box and have a look at making up a few more components/sub-assemblies. Or perhaps tap a crankpin bush or two and take some more piccies.
Steph
