Steph Dale
Well, that's the idea anyway!
I've had a couple of inquiries about how to make an electrically split crank axle and so thought it was probably time to put my money where my mouth is.
So here's an approach to making an insulated crank axle for a Slater's axle/wheel set using Laurie Griffin components. It's going to be a bit of a blow by blow account so may take me a little while to get to the end of the description, I hope you'll bear with me.
So to start. We'll come to the components and ideas in a moment, but first I feel I should say that if this is either your first crank axle or you first go at split axles it probably shouldn't be! It will help enormously if you've done a few of each before you start trying to combine the two.
We'll start with the crank axle this evening and worry about the insulation a little later.
Pics shortly!
Steph
Pics shortly!
Steph
