Thought I would try Simon's approach to the PMV races today by totally ignoring the fact I was in a race
Instead, I went to a friends and had a play in the sunshine with my Accucraft Leader and the narrow gauge coach. It was a first run for the latter, and the first continuous circuit run for the former. I have to say, she was a bit of a b*gger to light this afternoon, a combination of cold weather and in my opinion, too much air at the back of the burner. I think the lack of restrictor there is having an impact so I shall have to make one up. There are new gas and regulator valves from The Train Department in the states to try too, the standard controls are quite coarse and I would prefer a little more refinement in control. Still, she ran for half an hour and nothing went wrong, result for my first steam up of the year
In true scattergun fashion I have also started the construction of another kit
Although its a change in materials, I've managed to stay with G1, but this one is at 10mm:foot rather than 1/32. Its a model of the GCR 15ton Bogie Fish Vans and it came from
Andy at Woodbury Models. Laser cut from mdf and ply, there are some lovely little location aids that allow a large percentage of it to be put together without glue or rubber bands. It was the first kit out of Andy's new laser and whilst it isn't production ready yet, I've not find anything that needs correcting on the body side of things. Andy is doing me a favour, I want/need some to go behind a new engine and he has agreed to do me a set of bodies, leaving me up to my own devices to sort out bogies, buffers, underframe details etc. I know Andy plans to get there eventually and sell the kit as complete, but I'm not that patient and with no defined timescale I'm grateful for the opportunity to crack on.
A couple of shots of it as it arrived, starting with the body parts
There is an internal structure which is built first to keep everything square
The chassis copies the original in terms of layout, but for the sake of simplicity, the channel section is just sections of mdf.
It all slots together quite nicely, although the diagonals need a bit of shaping
The body starts with assembly of the internal structure which either slots together or uses tabs for location
The roof formers simply locate into the slots provided on the upper level of the internal structure and you can see the cruciform locating tabes used to locate the body sides.
The body sides are a layer of thin ply, overlaid with an mdf fretwork
The ends follow a similar pattern
As do the doors
Although the door are loosely mocked up in the above photo, everything else is just slotted together. In terms of the real build, the internal structure has just been glued together on mine and is drying with the sides loosely located on the cruciforms to keep it all in alignment. The doors have been built as quick subassemblies, I hope I can get away with 20 minute sessions over the next week to bring it up to the 'mock up' standard seen above.
As for the new engine which started this lot off...
Its a Tom Barrett GCR D9, meths fired with a single cylinder and slip eccentric valve gear. With no sight glass or axle pump its very different to the Castle and will provide a good contrast and I dare say it, a bit of a challenge
It was restored by the chap I bought it off, when he picked it up it was in a sorry state indeed and aside from the cylinder block and crankshaft, it has been 'nut and bolted'. I've been able to trace the first three owners and have spoken to the second owner who wanted it back.. no chance! I've been after a Barrett for a while and they don't seem to come up for sale that often, or if they do, its all word of mouth - just like this one really! A chance comment that I was looking for another engine to run over the summer elicited the response 'You can buy the Great Central if you want', there was a
very short pause and we shook hands on the deal
I've not run it yet, there are a couple of minor snags I would like to deal with and I may have to bite the bullet and strip it down to get some more lagging around the boiler to prevent the paint from discolouring any further. Having bought a working engine instead of another kit I really don't want to take it apart, but then I don't want to respray it or damage the paintwork any more. It'll have at least one run though while I make up my mind
Steve
