If only Tom. And as you probably know it will be blue and grey and not PO Red!(Thanks for the offer though Mike) Still trying to make my mind up wether to add the door handles and handrails now or after painting? I would like to solder them on now rather than glue later, nice stronger joints for the rough handling it will get later!
Also added Westdale whitemetal door window frames to the ones that would drop.
I'm sure Steph Dale mentioned some suitable material on here somewhere. Something to do with fishing or something...Thanks Mike. I did file down the spigots on the JLTRT ETH equipment but obviously not enough. The tubing I used for No2 End isn't bad but as usual I did not have enough to do both ends so No1 End is a bit thicker. It's one of those things that will get replaced easy enough later. Flexible tubing is one of those diesel bits you need a lot but can you get hold of any decent stuff? I am using bits from my previous DJH kits as they have a nice supply of varying sizes but we don't know who their suppler is as I would willingly get a reel of the stuff![]()
