Ressaldar
Hi all,
I have swapped my untouched two-tone green 47 for a plain green 20 and, subject to obtaining the correct shaped buffers - (I need ovals in lieu of the rounds) I plan to produce 20008 in BLUE as running in the late 80s with the large numbers & Kingfisher emblem (I have had the set of transfers from Precision for some time now.
The other area that seems to need changing (apart from the buffers) is the removal of two lights from the rear cabsheet, and a 'plate' to fix between the rear cab windows.
Having removed the headcode discs from the rear of the cab, the white leds that are to remain, are quite prominent - is it ok to file them down or do I replace them?
...........will you be doing a Heljan 33 or the Deltic ?
