A small yard for a micro-layout
Tim Hale
It seems likely that the micro will develop as a new entity, rather than continue, a new thread has emerged, click on the link.
The idea of a micro seems to have gained some traction, partially due to the existence of three completed lightweight baseboards that have been laid with track albeit just a running line and a single siding to the yard. Moreover, the mainboard is acceptable to the domestic authority, it is a safer option than wandering down the garden to the workshop. Rather than a layout, it is 100cm mainboard and capable of detailing like a diorama, mostly inspired by Yorkshire Dave’s mini-scenes and I might get invited to bore at Expos.
The theme is a change from the usual rural early ‘50s to the ‘70s and an urban environment based on a small rail-served yard, something that is almost a thing of the past. Just a single hydraulic shunter and three steel opens located somewhere amongst the extensive inland harbour outside Bamberg, the railsystem will be the Bamberger Hafen Eisenbahn and the locomotive will be called Inga (a friend’s mum)
Like most small scrapyards it is a family business and a Wiking MB L406 is the ideal modern horse and dray, spot-on for the period.
Tim
michael080
Interesting theme, Tim!
I recall that scrap metal collections were common in the 70s. They were announced and everbody just put old boilers, broken washing machines or whatever just outside for collection. Your 706 is spot on! The trucks collecting everything were typically old and very shabby. I think they had some selfmade extensions of their side panels to increase capacity.
Btw., Inga is more common in northern Germany or the nordic countries. The southern German variant would be Inge. :)
Michael
Allen M
There are quite a few people still in Kidderminster who remember Bob Peden, the local scrap man with his horse & cart. He used the cart with several different horses from about 1964 and then for must have been 25 years, possible longer. He then went to a truck. He is now in his his late 70s but still does the odd small job with a trailer behind his car.
Allen
Heather Kay
It’s still fairly common round here to see a superannuated Ford Transit or Mercedes Sprinter creaking round the local estates, loaded with old barbecues, expired white goods, and broken bicycles.
I’m convinced they have a satellite spy network because you only need to dump something metallic at the end of your drive to summon the nearest vehicle to collect in minutes!
Same in west Kent (sometimes the cycles are even meant to be disposed of, rather too often, that’s not the case).
Richard Gawler
'Schrottbetrieb' can translate into English as a scrap metal operation, business, enterprise or even division; all of these more informative and more pleasing than our usual 'yard'.
What is interesting is the sign's typeface which looks to be a hangover from pre-war styles - the use of the uncrossed f instead of s in Munckerstraße (on the other hand it may well be a pre-war sign). Interesting looking at their website they are still in business today recycling metals and now textiles.
The eszett ß for the double s in strasse remains common today in street names - except West Berlin (later Berlin). They have their own typeface and the eszett ß appears as fz in straße. In other cases the use of the uncrossed f for s has been replaced by s.
The uncrossed f for s also appears in old english text and you occasionally see the uncrossed f in the middle of and the s at the end of the same word. This may well be indicative of the Anglo-Saxon origin of both languages.
Apologies for the diversion. :)
michael080
it's me again, the old German language grouser.
Schottbetrieb is quite an exaggeration. Junk merchants were not the most reputable business, so Schrottbetrieb sounds very impressive compared to what we see through the gates.
If you are planning to have a small junk merchant, as far as I remember they didn't have much of sign anyway. Certainly not that size.
Michael
michael080
Tim,
don't get me wrong: You notice the joke with the "Hinkelstein"?
Typically, menhirs were not standard merchandise at coalyards.
Michael
Joe's Garage
I do " like" this sort of photo as it provokes so many ideas about a small layout. The little blue diesel squeezing between walls and a gate....what more can I say.... lovely.
A Merry Christmas to you, Tim and yours. All the best for 2024.
Julian
Not dark and satanic oop north anymore. - t'mills have either been cleaned or demolished.
When William Blake penned the poem in 1804 he was referring to the Albion Flour Mills in Southwark, then being the first major factory in London.
The term dark Satanic Mills later become used for wool and cotton mills and any other factory or mine which was seen as a mechanism for enslavement while the industrial revolution gathered pace.
Tim Hale
Finally managed to find the Grassmaster static grass applicator, for some strange reason it was lurking amongst the box of fishing tackle....however now the long unkempt grass can be 'planted' along the boundary fence and on the front edge.
The front edge has been enhanced with some pieces of foamboard recovered from 'Beaminster Road'. it had been painted brown and liberally covered in grass, although just 5mm high, it breaks up the monotonous 'flatness' of the diorama.
I need to weather the ballast, the track was painted at the outset but the ballast is much too new, any suggestions?
Unfortunately, the project is complete, it should be going to an exhibition but that is doubtful, instead it will be popped into its storage box and simply forgotten about.
Tim
Neil
I do like the concept of the scrap yard though I realise that you're not happy with its compromises. I have an idea brewing in my mind that takes the same principle but applies it to a different prototype.
Tim Hale
Hi,
The choice to replace the 8” wide layout will simply use the G&H single 16”x48” board as an Inglenook plan with two turnouts loosely based on James Hilton’s Cornish Inglenook.
However the initial choice of Fleischmann Oe was a tragic mistake, I have always trusted the company but their choice of a 3-pole fold-up frame motor driving low ratio gears meant two speeds, stop and cartoon. Instead, the tried and tested HO stock box will be raided for the scrapyard.
Schrottbetrieb
Tim
Tim Hale
A project restart requires a new mechanical handler, this looks rather bizarre or interesting.
The Bischoff Polytrac front loader was a bit of a failure in the ‘50s and soon replaced by better machines consequently, they were rapidly sold off to construction equipment firms and other menial work.
Tim
Tim Hale
Sunday morn, always in the workshop, having fun with the boss's beloved Tempo
Unfortunately I could only find the Busch version but hey ho....beggars can't be choosers
But that doesn't stop us bodging, it came from together quite easily
Still needs wipers, mirrors and weathering but it is getting there, Modellu version of Walter is also needed.
All the bits needed for the layout are ready for attention, hopefully up and running before August, much of the bits are already built.
Tim
Tim Hale
Walter Bensohn needs somewhere to conduct business in the yard and a tiny East German QEK caravan that was brought in for scrapping is ideal.
This is how it was, when it came out of the factory:-
And twenty odd years later:-
Neglect and the Northern European climate have taken their toll. The chassis needs to be refitted but the green mould has already taken over.
Tim
