Last one as it is starting to get repetitive.
Claud Hamilton from set PG3 with wheels:
As before artwork for the wheels has been done in Inkscape and are quite simple close up:
The chassis has been split in half and joined to provide a 5.5mm wide base and separate loco and tender:
Wheels are done using my usual method, laminating three layers of card for the faces and a larger circle for the flange. The flanges had to be cut with a compass cutter as my hollow punches only went up to 10mm:
The wheels added to the loco frames and tops trimmed flush:
Sideframes cut appropriately and fixed to footplate/chassis. Coupling rods added and tender sideframe overlays added.:
