Len Cattley
Great to see you back, we have been watching the floods and feel very sorry for everybody who have been flooded out. Looks like you need another Noah
. I've made a conscious decision not to make any more smoke box doors opening at the minute as it just eats into too much time, so smoke box door fixed, it just needs a lace pin head for handle on this side.
Just a quick update as to whats happening on my Workbench. First job was to set about hacking up my BV's so that I could fit sprung W-irons and S7 wheels. What a pain in the backside this was, I went through a job lot of blades and made a right mess![]()
[attachimg=1]
[attachimg=2]
I also had a day out to Shildon and took some pictures of an LNER van there to model the vacum cylinder assembley and underframe details. The BR vans didn't have these fitted,
[attachimg=3]
Not a great picture but it was inside a goods shedBoth vans are nearly finished and this one needs the vacum cylinder and another few bits finishing. Couplings and buffers fitted for now for the West Mersea test run
[attachimg=4]
Also nearly there on the Tube wagon, I just need some suitable axleboes, door chains ( from the place Steph recommended ) and a replacement buffer. I bought some JP recommended for Invertrain but managed to damage one housing beyond repair![]()
A trip to Halifax in June should source these parts.
[attachimg=5]
ATB Mick
There aren't that many bolts.Hi Mick,
Lovely clean, square and tidy work - very nice.
One thing I noticed about the splasher securing strip is how thick it is. I wonder whether you may be better off using some thicker scrap etch or bar and drilling the holes for scale hardware boltsThere aren't that many bolts.
Or make your own riveted strip using the technique shown on the scratchbuilding a wagon thread Steel 13T PO Wagon - the practicals | Western Thunder
Hi Chris,
Sorry I'm not sure how that works but i'll have a look through my pictures when I get a chance. I'm glad my thread was of help, the pictures are of an LNER van at Shildon. Unfortunately at the time it was inside the goods shed and the pictures aren't great. I keep meaning to take some more the next time i'm up there as it now lives outside. Great job on your van, I do like these kits and I have two to build at some stage.
Cheers Mick.R
If your going to punch a thin strip then punch a strip that is at least three times as big as you want and then trim back to size, that way you'll minimise distortion when punching, I'd get a GW rivet punch too, may be an expense you don't want, but for ease and accuracy it's worth every penny.
It's too late now but I would of made the riveted strip a plate that fits under the splasher / sand box, soldered to the frame and then solder the sandbox / splasher on top and finally trimmed the inside to clear the wheels.
Mick D
Thanks Mick,
The bodge arrangement I went for is in the photo below:
And current state of play is below plus some primer...
