P A D
Next up through the works will be the 7mm Gladiator Fowler 2-6-4t with limousine cab. His is another design by John Firminger which David Hill has taken into his range.
Here's what you get in the box.
Brass etchings. The tank/cab and bunker sides and rear have the half etched rivets on the reverse sides in this image, but there are lots to punch out. The cab roof is half etched with the rivets and vent rails in relief. That will make for easy forming without the need to aneal.
The boiler and smoke box are ready rolled with the rivets punched out. You get the usual assortment of wires and rods for handrails etc.
The chassis etches are quite substantial nickel silver, as was the Horwich Mogul.
And bags of lovely brass and white metal castings.
I'm off out the garage to make a start.
Peter
Peter
