Parkside kit instructions were one of the better ones but since Peco took them over they have been 'modified' .Simple and strong: Bent wire soldered to cross beam....................Plastic detailing parts glued either side....
View attachment 173859View attachment 173860
Stronger than gluing plastic rod to plastic bar...''''''''''''''''''''''''''''''''''''''Brake pull rod detail...
View attachment 173861View attachment 173862
Following instructions put brake lever in way of steps..................... Glued back the removed parts to offset the brake lever...
View attachment 173863View attachment 173864
Cast whitemetal vac and steam pipes attached with split pins... I wouldn't have trusted glue...
View attachment 173866View attachment 173867
Lamp irons have fallen off already, but I aim to get some lost-wax fittings for these and door handles....
Which couplings do you 7mm guys use......?Larry, aaargh brass!!!
you’ve got to get some metal black on those couplings!
I use Premier, same as yours, but I metal-black them - an alternative is a rub over with a permanent felt tip pen, anything to lose the brass / bright silver colours.Which couplings do you 7mm guys use......?![]()
I have bought blackened couplers at Dapol’s shop in Chirk. I think they sell packs of 5, both screw and 3 link. And while there they can also supply lost parts such as buffer springs. Just don’t look at the expensive items,
Paul
