LarryG
Mmmmm.You could always put round table tops on the posts and provide a few bar stools, ideal height for refreshment stands!
Long before I started building garden loops, I had a large rectangular shelf attached outside the shed wall and ran a loop of track around it to the fiddle yard. This is what I intend doing again. The beauty of such a construction is it can be full enclosed with a transparent lid (lean-too sheeting) so that trains can operated any in weather and there is no draft, wasp & bee ingress.Larry, does the elimination of the outdoor loops mean you are maintaining the layout as a terminus to fiddle yard?
Loctite Super glue. Each step was held in tweezers and one end dipped in a blob of Loctite before placing into each slot. It all set very quickly. Then the other side of the steps were eased into the remaining staircase stringer and Loctite run across the slots and wiped clean.Larry,
which/why Loctite?
cherrs
The steps could be attached right outside the door if the vestibule is left off. Also, Intentio offers an alternative left-hand version of this signal box.Larry
Can the steps be fitted on the other side?
regards
Hi Peter, Mighty grateful for this. Most useful during painting.When I took it, I hoped my picture might be useful some day.
It just took 55 years!
Peter
