Wouldn't a shotgun be easier?Right as a birthday treat, I'm off to shoot some clays with the eldest daughter...pull!
I don't have any of the 40" to hand to confirm but the smaller ones have about 2.7mm diameter bore in the insulating muff and the hole through the wheel looks like 3/16". I have mounted them on 1/8" axles by turning the ends of the axles down to suit the wheels, you could do exactly the same with 3/16" axles. Not sure what diameters the US model diesel trucks use as standard but it is unlikely to be anything simple like 1/8".Cheers, look good value for money but no information on what size axle they fit. I was hoping to use Stephs remote gearboxes so would require 3/16" axles, I'm going to guess they're using 1/8" axles. I could drill the wheel boss to the larger size I suppose, but doubt there will be much meat left on the insulated centre after that.
Put it down...
Walk away...
Switch the light off...
Shut the door!
Sorry to see that mate...
JB.
