Steph Dale
Rob, are the bearings a direct fit, or do you need to make modifications ?![]()
Phill,
I'm just gonna butt right in here...:
No mods needed in my experience, just open the holes in the frame up to take the bearing and then assemble as per normal. Of course, the ball races need to fitted with epoxy after all the other soldering is done.
So, rough order for assembly with ball races (should have done this before!
), the method would need a slight change around steps 3 to 6 if using plain bearings, soldered in:1 Burnish the gears to remove any burrs or roughness
2 Open out the holes in the fret to take the bearings, motor screws, motor bearing boss etc.
3 Fold up and assemble frame - as square as possible, with solder reinforcement to each fold and joint.
4 Clean up frame and blacken or paint if desired.
5 Using a 'jury' axle fit the ball races to the frame with epoxy.
6 Allow epoxy to cure.
7 Fit the motor with screws just nipped up.
8 Fit worm to motor shaft with a 2mm id washer between motor bearing boss and worm gear to take out any slack - but don't make it tight enough that it impedes the motor turning (I use Alan Gibson turned brass ones).
9 Fit gear to jury axle, centred under worm.
10 Adjust mesh, tighten screws.
11 Test run motor and gearbox.
12 Once happy it's smooth and quiet lock off the motor fixing screws.
13 Run in with a good quality gear lube.
Running in should be done gently at this stage (say 15mins one direction, rest for 15 mins, 15 mins other direction, rest for 15 mins, repeat) so that the motor doesn't overheat and so that the initial wear on the gears is even. Once the motor/gearbox has accumulated a total of about an hour in each direction it can then be considered ready for installation into the model. I assume we all run in motor/gearbox units on the bench before installation - whatever their source? Whaddya mean, no?
Seriously, it's good practice to get the motor brushes bedded in properly, ensure the motor bearings don't get deformed, burnish the gears, etc, etc. But mainly to ensure that if you get any poor running once the motor is fitted to the chassis - you know it's not the motor/gearbox unit that's the problem. Steph
, I'd of expected more from a brand new reamer.
