Mick,
I've been watching your builds ever since I first came across the Finney 7 W1 development. Your soldering and assembly work is second to none but with your CAD and 3D printing skills you are able to lift any kit, no matter how good to start with, to another level. Utterly superb!
Peter
Well thank you young man :thumbs: :D
Soldering is easy to explain, I'm lazy, the less I put on the less I have to take off ;) or more importantly on exposed faces/edges.
3D prints are a recent factor in the hobby, I don't (as many have subscribed in the past) add them willy nilly, they're there for a reason and it'll be one of two primary factors, the originals are from tired moulds and look dreadful or are even missing, that extra detail component isn't part of the original kit design; if the kit castings are acceptable then they go on.
CAD was always my strongest arrow in my quiver, that came long before (I did 3D sim work for flight sim and train sim) soldering and metal work (mind I did some 4mm white metal models in my late teens before totally getting out of model trains for 30+ years), that all came to fruition when I started posting on here way back yonder.
Frustrated by the lack of overall gumption from some sellers I looked around and self taught a few aspects; one commercial vendor at a show said, if you think etches and 3D artwork is so easy then why don't you go and do it yourself! So I did and here we are now, at the time I was royally pi55ed off but in hindsight that one comment set the path for my future.
Anyway, I hope posting what can be achieved helps some people to open their minds a little more, we can't always live in the past and new skill sets can be learned if you have the will, I don't subscribe to the mindset 'I couldn't do that', most people can they just choose not to.
I have to confess that your work was a positive example of what can be achieved, take something normal and move it on to the next level so don't be so shy on what you've achieving, it is very good.
Thanks for the kind words Mick. I guess in the end it's the builder who determines the quality of the model, not the kit.
Peter
Maybe a bit of both.
There are builders who can make a silk purse, but why bother?
Equally, in the wrong hands any kit will produce a disappointing model.
James
Definitely!
I bought a built 74XX and as a result of the original (perhaps due to inexperience?) it was never going to work as it should have done. The kit itself was fundamentally sound.
Post in thread '14XX and 74XX' 7mm - 14XX and 74XX
SWMR 645 back from paint and pre assembled ready for the fitting out shop. Just need to straighten that handrail at the front a touch, looking at the final build photos it looks like it was a tad out before shipping but it's an easy tweak and if that's the only (and so far it seems to be) issue I'll be a happy camper.
Paint by Warren Haywood.
spikey faz
Them gold injectors could do with some copper plumbing as well! Then can I have it?
They're not quite as gold as they look in the photos :)) but they do need something, either flattening back with a black wash or a better brass colour, that's the downside of white metal castings to represent brass fittings, they have to be painted :headbang:
The pipework gets fitted in the fitting out shop, as do lift rings, tool boxes, sand boxes, cab floor, backhead, glazing, coal, hooks etc :thumbs:
Fitzroy
Dare I ask it, was any steam fitting actually Brass? I would have thought anything that saw steam would be copper or bronze. The tank is looking lovely Mickoo, any chance of seeing the backhead?
Pieter
Pieter
It's not fitted out yet I'm afraid.
Mini update, the Star progresses, a few more things to fit to the footplate before embarking on the 'kettle', it's often easier to add things like reach rod brackets, name plate brackets and sanding rods before the boiler obstructs your work flow and often instructions tell you to do it later. Everyone's work flow is different but I find soldering from the rear without the boiler in place much easier.
Also, the Finney7 94xx is re assembled and shuffled into the fitting out shop. The orginal plan was to use the Slaters GB30R-3m (purchased & fitted) but the more I look at it under slung below the chassis, the more tempted I am to try a GB40L in there, the ratio would be better suited as well.
The 40R gearbox has more bulk above the axle line (fitted L orientation) than the 30R-3M so I need to check it doesn't protrude above the chassis top/footplate line.
Paint by Paul Moore (body), chassis by myself.
Dave Holt
Wow. Those gearbox sides look pretty chunky. Not much flex there, compared with the typical fold-up etched examples.
Dave.
Dave.
Slaters three stage gearbox I believe and yes, nice and chunky. I don't think I've previously ever made or fitted a fold up gearbox commercially and I'm close to 70 models now, the recent Coffee Pot may be my first.
More progress on the JLTRT Star, it's always the little bits at the end that take the greatest time, you think I'd have learned that after five years :rolleyes:.
The boiler is plonked on but there are a couple of little things that need doing first before final fitting and then gap filling where required, but on the whole it snuggles in nicely.
