ScottW
With a number of projects recently started I thought now would be a good time to begin posting notes on their progress.
North British Railway 4-4-0T, Class R
So to begin with here is the first progress report on a North British Railway 4-4-0T, Class R (LNER D51). The basic bogie has been made with the intention of adding the remaining detail once the bogie has been married to the main frames.
The wheels have been turned from solid steel; these being kindly done for me by Trevor Nunn of East Lynn fame. With the wheels being made of steel split axles were required to insulate the two ends of the axles from each other, with the bogie frames being electrically isolated by using a PCB frame spacer. One feature of the bogie on these 4-4-0T's was the narrow frames and external axleboxes. To try and represent this I have used Exactoscale 2mm axleboxes (designed for 4mm scale) soldered onto the outside of the bogie frames.
Regards,
Scott
Regards,
Scott
I have a set of the brass wheel castings in front of me at the moment to start on a Caledonian 670 class. But I've got to get the April Gazette out first.
