P A D
The loco chassis is slowly coming back together. I've already given it a good run in and it now runs nicely back and forth on a length of flexitrack on the bench.
The tender is now done reassembly wise, bar the buffer heads, but they will only be fitted after the buffer beam and hoses are painted.
Unlike the "traditional" Gladiator kits, the cylinders and motion cannot be removed as a complete sub assembly. The valve gear needs quite a lot of disassembly before the cylinders/slidbars are removed independently, one at a time from each side. Reassembly is therefore more complex. This is the state of play so far.
Peter
Peter
