Crook Street Works - Gladiator LNW Class C
Allan
Hi All,
Although Gladiator distribute this kit it has it's origins in the good old Modeller's World range dating from the early days of etched kits. I must have made all of their kits over the years although never bought from them - I was modelling 4mm when they were around.
Anyway, I started with the tender as usual. Nothing much to report here, it's the same as all the other Webb tenders I've built except to add lamp socket holes in the buffer beam, operating self-contained front buffers and my toy-like but operator friendly coupling post at the front:
I then moved on to the engine, starting with the coupling rods as they set the dimensions for the running chassis:
I then soldered up the frames, fitting Slaters hornblocks - no getting away with quick and dirty wire-sprung top hat bearings on this one as the insides of the frames are very visible on this small boilered engine. The front rods are rivetted to the second making a two rod unit - a legacy on the prototype of it's origin as a 3 cylinder compound, the cotter pinned front bearing being made to clear the outside cylinders:
It ran sort of ok, I wasn't really happy with it's very slow running and I didn't want to open up the bearing holes even more, so I'll leave it until the DCC chip is fitted and see if that smooths things out. A bit of a puzzle as I took my usual due care and attention to dimensions, squareness and alignments, which usually works but not on this occasion. Let's see how it pans out:
So I moved on to the footplate - there's still a lot of detail to add to the chassis but I like to get the main sub-assemblies built to ensure it all fits together and there's no dimensional anomalies.
I'll continue on another post to keep within the photo limit...
Allan
Allan
Hi All,
To continue...
So the first anomaly to correct was to lugs on the chassis that foul the footplate valances. Not exactly sure what they're for - to mount rear sandboxes perhaps...?
So they were unceremonously chopped off and my favoured angle soldered to the drag beam to locate the rear of the body so it only needs one screw at the front and doesn't need a second one to be somehow disguised (I've never worked out how) in the cab:
There's no intermediate boiler formers in the kit so I made some up and the boiler was suitably tamed, this picture is before I smoothed off my chicken s**t soldering...:
...and it and the cab drilled so I can affix it after painting and lining:
so with a bit of fettling, it fitted nicely. The cut outs in the smokebox are to clear the handrail knobs and will be hidden by the riveted wrapper:
The front sandboxes are a symphony in origami and fold up as a single unit:
Unfortunately, they don't fit...!
So, with a lot of soldering, filing and cursing, I made a passable - not perfect - extension to them:
That's as far as I've got so far, as it's summer, its a fairly slow build so I'll post the next update when progress is substantial enough.
Allan
john lewsey
I'm liking this, I have been thinking about one of these for sometime. It looks like a C already. We both seem to have a thing for 0_8_0 s Allan .
Interesting - it seems a little bit of a Curate's Egg to me. Some of the castings seem a little ropey and need quite a bit of fettling to tidy up. It would be nice to find a well designed Webb tender based on the latest methods for high end kits.
10 out of 10 for perseverance, I think with that fit I'd have given up, figuring out scratch building a replacement unit would have been easier.
Brian McKenzie
I then soldered up the frames, fitting Slaters hornblocks . . . .
Allan, I'm wondering if the springs used on the axles, to push the axleboxes and hornblocks outward, are too strong?
The hornblocks, being cast (although superbly from injection mouldings), don't have quite the precision a machined component might have. Any minor variation in wall thickness, flatness and alignment within the casting can transfer to the axlebox - potentially affecting the squareness of the box to the axle.
I've more recently learnt to let the axlebox guide the hornblock gently without spring pressure, and allow the solder to fill any uneveness between the back face of hornblock and frame plate. This kept the axles spinning freely.
-Brian McK.
john lewsey
Allan
Ah John, you've outed me! I do indeed have a predilection for 0-8-0s. They're something of their time, quite incongruous compared to later engines we're perhaps more familiar with. Their day was the first 30 years of the 20th century when these strange dinosaurs would be seen huffing and snorting everywhere...
Ok, ok, so I'm an old romantic...
Allan
Allan
I nearly did, it was a close run thing. I reckoned it would be quicker to add a bit to the end and file it to shape. It wasn't too bad really.
I think the necessity of learning 3d CAD and 3d printing is coming out of the walls at me... Especially with the retirement of Laurie Griffin.
Allan
Allan
-Brian McK.
That's certainly a consideration. I usually ream the axle boxes post installation if there's any binding. The puzzle on this one is that it was so smooth as a push-along. I checked the motor and gearbox separately as well. I had a similar problem years ago with my 5'6" tank. I just could not get it to slow run smoothly - and its just 4 coupled! When I fitted a DCC chip with the speed feedback inbuilt, it ran totally smoothly. Some you win, some you lose...
Allan
Mike W
When Modellers World introduced that tender kit it was the best thing they'd made up to that point. But times change and standards are improving so very quickly these days. Their first kits were whitemetal wagons and, although an LNWR fan, I just couldnt bring myself to buy one. By the time they brought out the 12-wheeled Dining Saloon they are a different standard altogether.
Genghis
‘This kit is a tale of three halves.......... The tender is the Adrian Rowland designed 1800 gallon Webb that Allan has vast experience with. It probably should be the 2000 gallon or 2500 gallon one, but not available from us..
The frames are a Peter Dobson design that was intended to be suitable for both the C and the D. I think the lugs were intended as part of the frame - body assembly, but that raises the question about footplate width. Your solution for the rear fixing is elegant.
The body ............. should really be in the scrap bin. The intention was to have it redrawn, but then Peter suffered his stroke, so it was on John Firminger's to-do list. I am loath to ask anyone else to join the club.’
The above was posted on the Guild website, following which John Dale has made an interesting suggestion and observation that he had been approached by Geoff Stratford to redraw the C body. Pity it didn’t happen as it would have good.
Hi Adrian, it's a Dragon models kit. They also do some LNWR locomotive kits
Thanks for that - I have seen their kits advertised, but they don't advertise the tender as a separate kit. Also their LNWR kits are currently out of stock. For various perverse reasons I'd like to build a LNWR Dreadnought so the tender I think is correct but I don't think anyone has ever made a kit in 7mm so it'd be another scratchbuild.
NickB
I make no claims as an LNWR expert but I did a lot of research on the 0-8-0s for my own project. Ted Talbot's book is a mine of useful information. What I gleaned can be summarised like this:
  • One or two of the earliest 0-8-0s may have hauled Webb 1800 gal tenders for a short time, but there is no hard evidence of that.
  • Webb 2000 gal tenders appeared on the A class new, which later became the C class, and photographic evidence shows a few with these tenders as late as 1920.
  • Following Webb's retirement in 1906, increasing numbers appeared with 2500 gal tenders which are quite a different design.
The visually significant differences between the Webb 1800 and 2000 gal tenders are:
  • The 2000 gal tender had thicker frames to increase the height of the footplate to match that of the engines.
  • The tank was wider and longer, and overlapped the rear beam, and that odd-shaped plank on the beam of the 1800 gal tenders was removed to make space.
That is not meant to be set in stone. It is difficult to know what happened all those years ago, and it is possible that you have other evidence.
All of which may or may not be helpful, depending on your attitude to prototype fidelity. And I've been playing trains long enough to know better than to raise that topic again.
Nick
john lewsey
Hi Adrian, I just phoned them and ordered it. I will be ordering another one to go with the B class that Nick Neaston is doing the etches for.
Allan
Just to add to the tender discussion. The LNWR accounted for and serviced their tenders separately from their engines, so a loco coming out of the works would be paired to the next available tender. My understanding (not complete by any means) is that the Webb tenders were all exchangeable with eachother. I think Claughton tenders weren't. There's a number of pictures around showing less than elegant combinations, Yeadon's Compendium of Goods Engines show a Coal Engine coupled to a 2000gal example and a Cauliflower with a 2500gal tender, which looks particularly incongruous. Good news for scurrilous modellers like me...
Allan
