Rewanui (1940 NZR in 1:64)
For those not familiar with NZR tarpaulins this photograph might help to show what Lawrence is trying to achieve. It looks like a 1930s view showing both traditional black dressed tarps (hot linseed oil and tar coated canvas) and 'modern' commercial canvas tarps. It also shows the grab handles well and truly covered by the tarps.
Tarps are very difficult to model convincingly so it will be good to see some convincing tarps on wagons.
Lawrence Boul
WHERE DID YOU FIND THAT?? (I tracked it down to Culture Waitaki) I've been trying for months to find a single image of tarps from that era!!
So thanks a lot.
Krusty will doubtless have things to say.
Lawrence Boul
A friend who knows about this stuff says "Car to the left is a 1936 Ford V8. Car in the foreground is a 1934 Hudson Terraplane. The truck along the road is a 1935 Chevrolet. So, the earliest it can be is 1936." Given that none of the vehicles is likely to be brand new, this would date the photo to the late 30s, or maybe early 40s, which means this look is just what I need to achieve.
Lawrence Boul
Staying with the 4 wheel wagon theme, 3D printing has obviously revolutionised what is possible.
My first printed kits (as built by @Overseer) were, more or less, derived straight from the original drawings.
This wagon (1/64 from a few years ago) has a 3D printed body on an etched underframe that in an earlier iteration carried an injection moulded body sourced from others. The print was quite an improvement. It didn't need fettling and filling, wasn't constrained by avoiding undercuts and had details like the chains to retain the door pins. Wagons like this though suffer somewhat from the uniformity and lack of character typical of RTR, and are somewhat soulless. (This example still awaiting hoses. The frustration of sidechains also evident).
It didn't take me too long to start thinking about distressing the underlying 3D model. It is not at all difficult to distort planks, replicate loose hinges etc to get something that looks a bit more used.
This one is 9mm/ft I think, but is the only image handy to show the initial development where the doors were allowed to sag and hang outwards against the pins. This simple step improves things quite a bit.
Shortly after, I was working on a simple coaling stage. This is possibly the most boring and featureless subject imaginable without the inclusion of character due to the vicissitudes of hard use. So I put in some effort to beat it up a bit. This was achieved by a) adding warp and twist to the planks and b) adding wood grain.
Grain is added (in Blender) by adding a texture to the timbers based on a real image of weathered planks. This is real 3D texture, not just a graphic fudge. The image shows my first attempt which I felt worked extremely well and was somewhat by luck than management. This printed timber was painted a light/mid grey and then treated with a black/brown enamel wash. That's it.
Thus encouraged, I predictably wanted some of this on wooden wagons as well.
This one is 9mm/ft. Wood grain, per se is not especially visible on the outside of a painted wagon. On the inside it can be heavier as, a) loads and weather will etch the timber a bit, and b) extra relief will allow weathering to show the grain. Depth of grain is very easy to adjust in software.
Around the time I was doing this @KrustySimplex pointed out that the distress in weathered timbers is primarily cracking not grain as such. If one can stand the critique, the merit of putting up one's work is that such observations lead to improvement.
Adding cracks is quite a bit easier than adding grain. That's useful as grain is exhausting and files get quite large (=slow). Being relatively simple cracking can realistically be varied between prints for an individual look.
L1-1350.jpgThis example (back to 1:64) is the latest iteration of an increasingly protracted development. Timber has grain and cracks (subtle here, but very worthwhile in the flesh). The model is printed in 1 piece with an etched brass floor (plus the odd cast and etched detail). Grain on the brass floor is drawn on with a pencil.
Couplers are now finally correct for my 1940 period. Thanks to prototype research from @KrustySimplex, I'm now able to get the combination of wagon body/underframe/axlebox/handgrab etc correct for the wagon number applied.
Another 1:64 highsider showing the underframe. Almost everything here is a single print (including axleboxes, brake shoes, brake stretchers and loops) other than brake linkages (etch/wire), shunters step, handgrabs etc. Axleguards are etch and the wagon has sprung suspension based on guitar string. Cat hair included at no extra charge.
These latest wagons are probably as far as I'm ever likely to go. I'm working on my painting, and doubtless there will be some incremental improvements in the models, software and printer capability. But there is a lot of work to bring other aspects of the layout to this standard, so it's unlikely I'll be putting much more effort into wooden highsiders.
Now I just need to build a fleet. Not too daunting as these things can be assembled in an hour or so. Painting them takes considerably longer.
Lawrence Boul
One of the banes of modelling the NZR is fitting side chains.
I've gone through various phases with this.
  • Way back, I formed the hooks from wire.
  • Then I etched a fret of hooks.
  • The next step was to cast them. The latest iteration is superb, but doesn't remove the need to sort out suitable chain and actually fit them (which involves breaking two links). Good for locomotives where robustness is critical, painful in all cases.
  • The final phase was to print the hook, chain and eye as one piece, but with the links free and separate. The link through hook and eye are not free in practice (in 1:64 anyway), but this doesn't affect the look or their ability to swing free.
The image is a 9mm wagon and an intermediate stage with cast eye, but the idea should be clear. The print supports are a bit heavy in this one, but from memory it represents my first try.
This works extremely well. It makes a task that took ages into a few seconds work. The result is scale and looks like it would take a load (cutlinks always look naff even if an effort is made to solder them closed). It works just as well in 1:64 and has proven perfectly robust. There's no load and the only real risk is snapping off the eye. Should that happen it's an easy thing to fix.
Lawrence Boul
Rewanui had a problem common to many layouts: how to hide the transition to the fiddle yard (of which there are two)? The first was easy since the real thing had tunnels that could be relocated. The second, in the foreground was trickier. The answer was a repositioned building modelled in relief as mentioned earlier in this thread.
I've always rather liked the building with its monolithic structure and church-like windows - a stark contrast to the weatherboard of the other structures at station level. I had quite a few images, but having conceived the idea to reposition it I needed some measurements. While it still exists, it's a day trip expedition to get there. Fortunately a search of Archives NZ turned up this:
It's not exactly as built, but together with the images, totally adequate to make my model. As it's mirrored and sliced obliquely, I can't get too hung up about the nearest mm.
The model is a styrene carcass with 3D printed doors, window reveals, chimney and the detailed areas of the foundation. Windows are laser cut.
This view of the CAD model shows the 3D prints (in grey) and the way the building was sliced at the backscene. The nearside foundation was not rendered, so I printed it to show the imprint of the timber boxing. The gutters/barges /soffits were one piece and arranged in a way that they positively located to the styrene walls. The styrene 'iron' roof (not drawn) sits over this.
In this progress shot the difference between the rendered and backside foundation finish is obvious. Also the way that the guttering is captured and made very robust by amalgamating it with the other parts.
The lamp shade was formed from shim in a simple 3D printed 2 part press tool.
The real thing in 1987.
Lawrence Boul
Based on the vehicles it must be post-1936, so say c.1938. Invaluable for me.
Happy to help. You will probably have seen the following images from The New Zealand Railway Magazine in the 1920s. The new tarp shop was built at Addington in 1926, published in Vol 1, Issue 5, 24 September 1926. This is a late date for the construction of a high clearance building to hang linseed oil dressed tarps (Victorian Railways stopped dressing tarps in 1924) but is reported to have continued in use for quite a few years. The North Island tarp shop was at East Town Workshops, Wanganui.
Lawrence Boul
This just shows I need to get a life...
Addington was still dressing tarps with Linseed oil way later than 1926. As this memo alludes, they tried the wax dressed tarp used in Australia, and these are probably the light tarps in the 30s photo. They were not particularly successful in NZ and it was a problem they sought a solution to. #3 and #4 involve linseed oil in 1941.
I think that is interesting, mainly for the lack of standardisation. I have attached a pdf file of a section of a Conservation Management Plan I wrote for the Tarp Shop at Newport Workshops in 2012 for a summary of the tarp situation in Victoria.
  • Newport Tarp Shop CMP extract.pdf
Lawrence Boul
@KrustySimplex is more knowledgeable than I on the matter, but it seems likely that NZR were trying the various solutions that were working in Australia. The advantages of wax dressing suitable for immediate use v hanging for 3 weeks are obvious. So the fact that they went back to linseed oil and vegetable black suggests that the wax was ineffective here.
Clearly they were using linseed oil in '42, and being none too careful about it either:
Lawrence Boul
Back to modelling...
One of the stars in the Rewanui show is the humble hopper wagon: class Q. These came in a number of flavours, but in 1940 they were all unbraked wagons of 8.5ton capacity. The hoppers were removable and on the wharf were craned over the ship's hold and discharged through the bottom doors. There were two distinct fleets, and only the Greymouth Qs were found at Rewanui. That means that some attention needs to be paid as not all varieties and variations are appropriate and wagon orientation and asymmetric lettering need to be observed. Handbrakes were arranged to be trailing on the gradient, door mechanisms were accessible to the 'wharfies' and wagon numbers visible to those tallying loads. As mine and port arrangements differed at Westport, so did these details.
I have, over the years, done quite a few iterations of hopper kits. My very first kit (in pewter) was a Q5. I've scratchbuilt and etched Q1, done etched kits for Q2/3 (before realising these were Westport only) and etched Q4 as well. All of these were reasonable, but all were time consuming. Punching rivets in steel hoppers is fun the first time, but if you need a fleet the appeal palls quickly.
So with the layout progressing I looked for a more practical method, for the numerous Q5.
The spec is:
  • quick to build
  • sprung
  • sufficiently heavy to perform
  • detailed inside and out
The result is an etched subframe, 3D printed visible underframe, cast platforms for weight and a 1 piece printed hopper.
_HLB1975.jpgHere's the subframe. A simple fold up with clip in crossmembers and a few solder joints. All the bits where strength and dimensional stability are needed.
The pretty bits are added. This is a positive fit.
Cast end platforms with the handbrake hanger, coupler mounts integrated and wire handgrabs added.
Again a clip fit - though obviously ultimately glued.
Suspension sorted. Cast sidechain parts, now revised to assemblies printed in one go.
The end (more or less) result. As with many of my projects, the problems have all been solved, so efforts have paused while I look at other choke points.
I need Q1, Q4, Q5 (here) and Q7 for Rewanui. Q1 and 4 have steel underframes and hoppers so my etched kits for those are being maintained, but the elegant, though interminable, etched hoppers have been replaced with prints. The fairly rare Q7 is a wooden hopper (similar to that above, but different) in a reused Q4 underframe.
So the hopper solutions are on hand, but I now need to build some...
If you can face it, the extended play version of this potted history is here: Coals to Greymouth – NEW ZEALAND FINESCALE
