7mm Scruft's Junction - folding table... down the garden path... Painting the engine shed!
I suppose, this approach would work with ballasting too? Though I guess I've found an excuse to put off my own ballasting for another week . . .
Yes, with care to avoid ballast getting into the crown of the clump.
Primo clumps (recommended) are packed as all of a single size - although there are a couple of lengths/heights in the range so little scope to relrepresent spreading vegetation.
Games Workshop clumps (also recommended) has several heights and widths in one pack plus a few longer lengths of thin width which is a good starting point for grass in cracks.
Both products benefit from trimming around the sides to remove stragglers (fibres which tend to lie flat).
Spike
Hmm, nearly a year later and Scruffs has been out twice and next weekend is at the Fareham show. For those that don't venture to the other place here are photos of the layout and what progress has happened since the layout appeared at its first show in March.
Colliery Screens - Cladding of the building is now complete though below the roof was not complete, up next is drawing and printing windows. Other detailing parts are to be added, and then a lot of paint.
Footpath, fencing and signs.
The foot crossing has had the fences added and some new figures have appeared which were painted by a younger member of the local railway club.
Signs were added from Monks gate models. Still need to added gates and finish painting the fencing.
Trees
The first trees were "planeted" today, they are Primo silver birches with a single Oak also included.
The coming week will see the layout packed up with a number of small jobs to finish before Friday.
Peter
Peter (@aka Spike) and I are taking Scruft's Jcn. to the Basingstoke MRS Open Day on Sunday April 12th. The Club Hut and adjacent Scout Hut (which we use for our open days) shall be open between 10.30 and 15.30. Admission is free. Sat Nav RG22 5HN ought to get you to Stratton Park where we can be found adjacent to the large car park and tennis courts.
If you model to 7mm scale using the S7 track standards then please consider bringing some stock to run during the day.
Regards, Graham
Spike
The engine shed has been the area of focus over the past month.
After applying primer to the shed ran into a challenge when applying the paint to represent the mortar courses, over primer it does not really work due to the texture of the primer. Quick read of LCut's site revealed a painting guide which recommended applying yacht varnish to the brickwork first. Two cans acquired from Amazon along with a few test pieces of walling from LCUT and ended up with a half decent looking wall.
Next up is painting the roof and tank of the shed. Went with GWR colours to tie in with the other buildings. The roof is railmatch slate.
Following Peter Goss' book on modelling buildings I started picking out individual bricks with various brick tones, at first I was not sure but overall I am pleased with the effect. Finally bit for now is the roof, again making reference to Peter's book followed his process and it works.
Next up is sorting the windows and doors, still need to decide on the guttering and interior.
40057
That sounds like good advice! I have had difficulties getting a good finish on LCUT brickwork.
I’ve been using LCUT brick-effect MDF for years. Obviously, I have never read the instructions …
Thanks for pointing out their recommendation. It had not occurred to me that their website might offer advice on using their products.
Martin
Shellac works well on MDF.
I've used Zinsser B-I-N Shellac-based primer on big flat MDF surfaces - available in white or grey and, I believe, an aerosol version if you look hard enough.
Dries super fast, takes oil or water-based paints well.
I wonder if the aerosol might be better than brushing from cans for the fine surface detail of laser cut brickwork?
So many similar-looking B-I-N tins, make sure you pick the Shellac one!
