The Norwich & Mucklemouth Railway - Eastern Eccentricity in EM
Herb Garden
The passenger stock project continues....
The 4th set of etches is for another diagram 502 or is it? Thanks once again to the support and guidance of @Buckjumper I've learnt something about this particular set of etches.
The ends on the etch are for a diagram 502 coach but the sides are for the last batch of diagram 503 brake 3rds so neither matches. So what I've decided is to correct the 502 I built last week to be a 502 and modify the 4th set of etches to be one of the last batch of 503s... The two main differences are that the 503s were 3in taller in interior height. 1mm in model form to the centre of the roof. The last batch of 503s gave recessed top panels otherwise they are basically the same coach
So here's the 503 coming on with the Hornby body underneath extended to make a 27ft body and the start of laying some extra plasticard on the roof to bulk it up by 1mm in the middle I've then just got to blend it down to meen the sides giving a tighter radius arc than on the previous vehicles.
What I love about passenger stock is that to the untrained eye it all looks the same but there are little details that provide wondrous variety
Simon H
Hi Simon,
Yes these are the Peter K ones. Goodness knows how old some of these etches were but some were almost brand new when I acquired them second hand
You can hopefully see the difference in levels of tarnish between the 2nd & 3rd form the left and the one of the far right.... Just goes to show it make a difference how you store etched parts
I think I must have bought mine at least 30 years ago and I got the impression that they weren't exactly the latest thing then.
Pretty sure I found out about them in an issue of "The Colonel" (Col. Stephens Society journal); IIRC there was a list of then currently available kits or parts that were applicable to the K&ESR...I also bought a D&S kit for a GWR outside framed goods brake van at about the same time, for example.
I've noticed quite a bit of variation in the condition of a lot of etches...perhaps something to do with who etched them and how long they hung about before being packaged, etc.?
Watching your progress with interest,
Simon.
Herb Garden
Simon.
Issue 31 of 'The Colonel' is the one you want. Can be downloaded from Thier website.
Whilst on a GERS zoom social tonight I've been able to make more progress on the 503 the roof shaping is complete. Ducket sides added and it has been dropped on to it's chassis.... Ride height still needs adjusting but it's getting there.
Getting there but still more to do and other tasks are piling up in the background.
Simon H
Thanks for that...I'd pretty much forgotten about the Society, as my modelling has gone in other directions recently. There's a (very) long term plan for an EM Gauge light railway, though I suspect it'll be freelance in nature...
Simon.
Herb Garden
So the fun of these etches is that they were definitely hand drawn which means there are some discrepancies between parts. No more obvious than the duckets.
Hopefully you can see the issue the individual ducket side doesn't match the coach end requiring yet more filing. But saying that it's starting to look like a finished coach.... Form this angle at least
Herb Garden
The basic form of the 503 is now complete! Absolute luxury if you were a 3rd class passenger in 1880s London
I'm trying to get them all to a basic form before detailing starts here it is posed with the 1870s diagram 216 composite.
They are still riding a little bit high if compared to the diagram 611 brake which is originally from the same era but I think I can adjust that.
Herb Garden
Hot on the heels of those coaches comes the next one
The diagram 501 is a Johnson suburban design dating back to 1872 or so it shares many features with the later 502 and 503 but has one less compartment.
We met it back in post 893 And at a length of 22ft 8in rather than the later 27ft the Hornby chassis (at a scale 26ft) has required drastic surgery
My first attempt made the wheelbase to short so I've had to cut and stretch the chassis again to make it suit the prototype.
You can see the blunder I made but it all will get covered up.
It will be a nice little coach when complete.
So here's the current state of play of the passenger fleet posed at Skeetsmere's station. Yep 8 coaches and not one finished... Even for me that's embarrassing. Probably with an up and coming exhibition deadline I will have to be selective which ones get finished first.
Bigjohn
Earlier in this thread smaller needle files were sought,. Not having read the full content of this thread, ESCAPEMENT FILES are available from watchmakers suppliers H S Walsh was my local supplier in S London, others are available. The quality ones are “Pricy” .various shapes round triangular etc. HTH……..….big J
Herb Garden
Gents, I will make a point of 'filing' those suggestions away for future use, very helpful thank you.
This is probably going to be the last update on passenger stock for a bit as some of the components to get the electrical issues have arrived and getting that aspects of the layout working needs to be a priority
The 501 has it's duckets done now.
The 502 also has it's duckets completed and I've started filling the top panels as the 502 didn't have these unlike the later batch of 503.
The most progress has been made on the 216. Roof, end steps, waist panels and door vents have been added so it's started looking like a coach.
Herb Garden
So I've had to face up to the challenge and turn the layout upside down. I'm proud of my wiring but even I have to admit that 2 years and quite a lot of hot fixes have left the underside of Skeetsmere in a mess.
Also this being one of my earlier control units I see things that on newer units I wouldn't dream of doing again. It's all a learning opportunity.
So there's a mix of things to do:
1. Remove redundant equipment
2. Make permanent the hot fixes
3. Renumber cables (changes due to lever frame change.
1st job is to remove the Arduino and servos that were going to run the level crossing and never worked IMG_20260414_214840258.jpg
Sadly I can't really make use of the free space much as I'm not going to move everything round as it's all set in place now. My hope in the future is to design a standard layout module using the same tech that can just be built on repeat but that is another challenge for another day.
In the meantime I'm getting on with updating wire numbers
GER R24R #382 New
Herb Garden
Theres lots of tidying up of wiring going on here at the moment but it doesn't make good post content.... So how about something completely different....
Folks outside the hobby find it strange that we would purchase an expensive locomotive then cut it up or take it to bits. But having been inspired by the work of my friend @Godders53 I've taken this cut and shut modelling style to heart and found it very rewarding. You saw what I did to the coaches didn't you?
Well here is another destructive project ....
I bought three Accurascale buckjumpers, the first you have allready seen and is nearly in service in as produced in GER blue. This one and another were bought to be painted into GER condition but after fitting it with EM wheels I thought it might be nice to do something a bit more creative with it.
Accurascale have produced many of the varieties of these locos but not all by a long shot. Given a full repaint was in order anyway some modifications to get something truly unique was not going to impact much. A bit like the rtr conversions George Dent did in model rail magazine in the Noughties... Before it got too commercialised.
This is the prototype then R24R (later LNER J69) number 382 like all the conversions from the original R24s it has widened tanks but these have the flare on to hide the condensing apparatus.
The new tank sides started as a spare moulding from a friend at Accurascale.
Soon reduced to a new set of sides
To get everything the right width I had to cut back the original tank side of the loco.... Not for the faint hearted.
But with prayers uttered... Perfectly feasible
And glued in place although I'm pretty sure I've now voided the warranty!
GER C72 #24 New
Herb Garden
And yet another buck....
The third and final Accurascale Buckjumper is the C72. Originally it was to be produced with an as built high roof but the artwork was changed late in the day. By this point it was allready or order so I figured I could do something to make it the way I wanted it.
This is what I wanted to create #24 as built seen here at Spitalfields.
The roof was built up using varying degrees of plasticard strip. I used the technique on the coaches why should it not work here....
It seems to have worked with an thin final roof over the sub frame with the relevant beading.
The smoke box door is another part from the box I was given by my friend.
Even more progress that expected was made as today was the April meet of our EMGS area group and we had a modelling afternoon up in Northumberland so I got the rods, brakes and some details added to #24
And to 382 as a matter of fact.... Both nearly ready for the paint shop
Herb Garden
The final Accurascale buck? Hardly....
In recent months I became the custodian of two of the engineering prototypes for the accurascale buck. Both were unpowered but reasonably complete and in good condition.
Our subject for this conversation is #335 one of the earliest rebuilds of the R24 class. Note the position of the safety valves.
We are uniquely lucky to have photos of both ends of the loco on the same day!
For this loco I decided just to build a brand new chassis and I'm using the south eastern fine cast chassis for the job.
High level gearbox and mashima motor help to complete the setup.
It sits a bit low on the chassis and needs packing up a bit but other than that it's well on the way.
Herb Garden
Meanwhile on other less locomotivey projects...
The good news is the wiring tidy up under Skeetsmere is now complete
Much neater!
Also whilst underneath I've taken the opportunity to upgrade the lighting connectors to something more heavy duty as it was the one thing that failed at the Workington show.
Sticking with the control system I've now finished the Lever frame. I was lucky enough to source 3 more levers of the older casting so it all now matches... Just needs painting.
But it wouldn't be a post on this thread without a buckjumper. So here's is E22 #253 a serial occasional aprearer on the thread. And I've finally scratch built a new smoke box for it. It would be good to get this one complete as it's the most appropriate loco I've got for the MSLR as it was actually on hire to the middy during independent years and then was allocated there after the middy was grouped in 1924 (yes that aint a typo).
Herb Garden
A bit more progress on 253
The soldering work on the body is now complete and can start gluing the details on.
I thought I wouldn't scratch build another smokebox door for this one and have used one of the left over ones from the accurascale bucks.
It's getting there and along with 151 it will be one of the two main locos when Skeetsmere goes to Wakefield
