4mm Llanfair
Dai88D
Most of my ideas pop up while lying in bed in a morning. This morning, I decided to take the loop outside of the shed. The scenery will be far less complicated, and the sound-fitted locos will sound like they are coming from somewhere else...
Funnily enough, i was thinking just before I saw this post wherher you’d venture outside again! You did this with an O gauge incarnation?
Muddysblues
Larry oh oh !!! you might want to hold onto that O gauge shed I just bought …. have you got my bank detail incase you want to refund me :rolleyes:
Craig
LarryG
It's hard to believe the foundations for my shed were laid down 20 years ago on 17th April 2006. And I still haven't a working layout.... :rolleyes:
Shortly after, an Austerity was purchased and detailed to match one I fired at Lees MPD. I didn't know about model railway forums and so Peco Code 100 ruled..... :D
LarryG
The internal loop and baseboard were removed and the 'mainline' extended to the hole in the shed wall. Moving back the overbridge has altered the whole balance of the layout...
It was fortuitous that the sharply curved siding adjacent to the backscene was formed with a Peco 2ft radius track template, and so I was able to slot in a 2ft radius small Y point. It looks like a catch point at the mo, but all will be revealed....
LarryG
Decent weather saw me wiring track. Couldn't be simpler, but there was a short somewhere. I dug up a point and laid a different one after testing. Great. Then another short occurred at the crossover. It can only be another dodgy point, so I've locked up for tonight.
It's re-using old points that is proving to be the problem
paulc
Your doing your bit for the planet by recycling, well done Larry . Probably doesn't make you feel any happier though .
LarryG
Armed with Antibiotics for tooth abscess, I had a day painting the rails. The dark track is where engines regularly stood beside the signalbox...
The short length of dodgy track in front of the goods shed door will be filled in eventually...
The GWR Small Prairie is on the loco shed road. At the moment, the shed "was demolished"...
The coal & watering facilities were useful, but there was no turntable...
The goods yard is Plan B (!) with the goods shed not obscuring the signalmans view...
Handy siding to store empty stock etc...
Dai88D
Commiserations on the abscess. You did well to get any work/play done!
LarryG
Embankment contours were drawn on two peices of 4" x 1" planed timber...
The timbers were cut out at an angle as shown and glued in place...
Crumpled newspaper etc was is used to support the Vinyl Grass sheet. It's a darn sight quicker and less messy than in the old days when I used chicken wire, bandages and plaster of Paris....
LarryG
Vinyl glass was glued to the wooden formers with Evostik Contact glue, pulled forward to the track, marked where to cut with a felt tip and trimmed with scissors...
A wedge of wood was added where the two sheets of Vinyl grass meet. A similar wedge is beside the road bridge.....
Vinyl grass was glued in place along it edges with Evostik and then shaped with a heatgun. Static grass and bushes and fences will hide a multitude of sins.....
Two hours of work saw it finished this morning. It look okay, but the addition of static grass will make it possible to more closely match the backscene...
I'm never concerned about creases. Static grass will hide them, but they are also useful for making dirt paths with water colours.
