Pete_S
Hi Rob.
Yes it is. Getting the ruler out, it looks like a difference of 1mm through the buffer centres.
Rob
An 8-compartment Third could be carrying 5 Tons of passengers (assuming 10st/pass & 10 pass/compt). That ought to flatten the springs a bit.
Flicking through what drawings I have (plus a dip into Russells Big Book of all Engines & That) suggests GWR C&W stock to have 3'5" to 3'5-1/2" buffer heights. Locos are 3'3" (850 class) and 3'4-1/2" (Star, 56XX). Tenders all seem to sit at 3'5".
Flaxfield
Noted, but.....these don't sag with added weight and wagons from Hornby and Rapido all share the same buffer height as the brake third. That said, I do see your point, Pete. and arguably the reletive buffer height of carriage and loco, based on your quoted figures, seems pretty prototypical......but it looks odd to these eyes.
Other locos checked all have the same buffer height as the coach.
This is my other 517 with the same coach.
It's intriguing.
Rob
Simon H
It's intriguing.
Rob
Intriguing indeed...oddly, differing buffer heights are quite common on continental H0 models; Märklin/Trix and Fleischmann often being noticeably taller than most others. I must say, 1159 is ever so tempting; just as well I don't model in 00!
Simon.
Heather Kay
I think we often forget that buffer heights were affected by loading. A loco with a full load of coal and water would be a bit lower on the springs than when things were used up. A fully laden wagon or coach would also vary.
I suppose there was a defined range, but I’ve never really thought about it, generally going with the "standard height for a model" route.
The RCH brought out a standard for buffer position in 1887 by the look of things
Before that I guess there would be variations between companies
RodneyS
Member
In a Scalefour Society newsletter many years ago there was a short article by Don Rowland concerning buffer heights.
This seemed to be mainly about wagons as he quoted the 'Regulations for the guidance of Train Examiners and Oilers 1962'.
This gives the minimum buffer height of a loaded wagon in service as 3' 1'' and the maximum buffer height for a repaired wagon passing out of the shops as 3' 6''.
On the LBSCR the buffer height of locos increased over the years. The Terriers as built had a buffer height of 3' 3 3/4''. Later on the Richmond class were 3' 4 1/2'' and even later the D3 were 3' 5 1/2''.
Perhaps this was a similar story on other railways.
Rodney
Jordan or Plymouth Mad
Mid-Western Thunderer
I know the issue of couplings is another subject, and an already-discussed moot point here, but with that gap introduced between vehicles by the couplers here, buffer height difference isn't really that much of an issue is it?
Just a genuine observation, not 'having a go'. As discussed before, Rob has said why he sticks with tension locks. :thumbs:
Hi Simon.
I rather fancy a take on the Bishops Castle Railway. They of course had a 517 but I fancy a rather ramshackle, far from Paddington, corner of the GWR Empire inspired by Horderley.
But it is some way off..
Rob
Lydhamheath looks interesting as well operationally with all trains reversing there, but could still be quite compact.
David Hall
