There must be proper scientific data on the performance of springs as used to drive timepieces and clockwork models.
Unfortunately, I don’t know where to look for it. I very likely wouldn’t understand the science anyway.
Anecdotally, then.
Springs get tired if used intensively or for long periods. True or false? A restorer of old clocks (I mean properly old, antique) would probably be the best person to definitively answer this question. Can a spring be regularly wound up for decades (or longer) and still power the clock? If performance does decline, how long before the spring ceases to store sufficient power for the clock to work? Do all springs behave similarly in this regard? Or do better quality springs last longer?
The only time I have asked a clock restorer for comment on the issue, he did say springs eventually became ‘tired’.
As for springs in model locomotives, I make the following observations.
1. Between the wars, Bassett-Lowke offered a repair service. My recollection is that replacing drive springs was specifically mentioned as a repair that could be undertaken. Meccano (Hornby) offered a repair service too, but I haven’t any information about what sorts of repairs their service would do.
2. It is rare, but I have seen locomotives that appear to have suffered a spring explosion. Most of the broken clockwork motors I have been able to examine had failed winding ratchets, rather than broken drive springs. Of the very few motors I have seen with broken springs, most of them were examples of the late 1920s Bing 6-coupled mechanism. I have never, for example, seen one of the large Bassett-Lowke 6-coupled mechs with a broken spring.
3. The vast majority of 100+ year old clockwork model locomotives show no signs of having ever had their drive spring replaced. They still work, often very well.
4. Over the years, I have had three locomotives (Bing, Hornby, Bassett-Lowke respectively) that had apparently sound motors which turned over freely and easily, yet they could hardly move themselves let alone pull a train. Tired springs was my assumption. But possibly defective springs, of faulty manufacture. These locos (motors) might have always been uselessly weak, hence no signs of use or wear.
5. Larger springs (longer, broader) can store more energy so locomotives with bigger springs are more powerful and/or travel further on one winding. (The balance between haulage capacity and length of run will be determined by gearing and driving wheel diameter). There is I am sure also an effect of how ‘hard’ the spring is; how much force is needed to bend the metal, so how much energy is stored. The late 1920s Bing 6-coupled mechanism I think would be widely acknowledged as the most powerful clockwork motor made for 0 gauge. It is seen in action here:
Note the loco slipping on starting, almost unheard of with clockwork. But with hardness may come brittleness. As mentioned above, based on a very small sample, anecdotally, I have seen relatively more broken springs in these powerful Bing motors. The similar-sized large Bassett-Lowke motors are not as powerful, but I have never seen one with a broken spring.
6. What load can a clockwork locomotive be expected to pull? That will depend of course on multiple variables including radius of curves, how free running the rolling stock is, etc. In terms of the present discussion, and whether or how quickly springs wear out, the question is: Did vintage clockwork locomotives pull more when new than they do today? Again, I can only report anecdotal information. When the large Bassett-Lowke 6-coupled mechanism was introduced, the company claimed it would, fully wound, run 120’ on reasonably straight track with a load of five coaches. A few years ago, I tested a locomotive powered by one of these mechanisms on a large circuit including 3’ radius curves. The locomotive pulled a load of five heavy Exley coaches around the circuit. The locomotive was built in 1930, the motor and, as far as I know, the spring have never been replaced. The locomotive was run frequently on a garden railway from c.1930–c.1960. The original owner said on the garden line, the usual load was 7 Exleys. Not much if any deterioration despite regular use. I am not knowledgeable about Hornby trains and don’t have copies of catalogues etc to refer to. However, my recollection from seeing 1930s Hornby boxed sets is that passenger sets with a 4-4-0 locomotive contained either two coaches — if clockwork — or three coaches if the loco was electric. Suggesting two coaches was the limit even when the clockwork mechanism was new.
I am not sure what conclusions can be drawn from the limited personal observations above. If anyone can add additional relevant information, that might help build a picture and allow some reliable generalisations.
Martin
