At long last, finally, my rebuilt Royal Scot (see my post #210) has entered works for repair. I say ‘repair’ but the works visit is to have its motor replaced. Remove the very well engineered, modern(ish), Bearwood Models electric motor and reinstate the correct, original, 1950s, variable-speed, Bassett-Lowke clockwork mechanism. I regard this as a ‘repair’ because the electric motor is anachronistic and inappropriate; the clockwork motor will restore the integrity of the model. It will again be a complete 1950s locomotive.
I repaired the Royal Scot’s tender last year (see my posts #247 and #250). Also, sorted out a problem with the clockwork motor (see my posts #349 and #362).
I admit to having put off changing the motor because it was a job I wasn’t looking forward to. Past experience suggests the slotted nuts securing the driving wheels (which were painted over after the wheels were fixed) and the crank pins, in particular, can be very reluctant to shift. So there is a risk of damage to paint-work or parts or fastenings. Anyway, I decided yesterday the job couldn’t be postponed any longer. I started by removing the front bogie. It is not necessary to remove the bogie to remove the motor. I did remove the bogie because the bogie is mounted on a swing link but is otherwise not restrained. It will bash the bottom of the cylinders or the slide bars or front footsteps every time the loco is turned over. The reason for removing the bogie is to prevent possible damage to paintwork.
As it happens, once the bogie was removed, I noticed both its side frames were slightly bent. Not something that would cause derailment, but better straightened — so that is done. I also noticed whilst handling the loco that one of the nameplates is loose. I’ll fix that while the loco is motor-less and I can get inside the splasher to reach the fastening. If I hadn’t had to replace the motor, very likely I would not have found either of these issues. I certainly wouldn’t have removed the motor just to tighten the nut holding the nameplate in position.
Here is 46100 today with the front bogie removed, prior to extracting the motor:
I took the electric motor out this afternoon. Reasonably straightforward. Except that unfortunately, by unlucky chance, the position the pistons were stopped meant that — on
both sides — the screw fastening the motor at the front was behind the cross-head. The wheels can’t be turned without applying power (I don’t have a suitable supply). I got the front motor fastenings out using a slim screw driver carefully inserted at an angle. Anyway, no damage, and the body is now set aside pending having the clockwork motor ready to install.
I also made a start this afternoon on removing the wheels, coupling rods and valve gear from the electric motor. I had hoped to remove the wheels with the coupling rods and valve gear still attached to them. However, more bad luck, on one side the slotted nuts securing two of the wheels on their axles were completely covered by the coupling rod. I will have to remove virtually all the crank pins and other fastenings to get all the wheels off the electric motor. Bother. So far, as expected, I have already found crank pins and slotted nuts that I have been unable to shift. I have spares (original parts) of these fastenings. So as long as I can — eventually — undo them, I can replace any that get damaged.
Martin
