It's been a busy week for work, so I haven't had that much time for modelling.
I have been building up the other 4 cylinders
4 are done and I still have to add the wrapper to the final two. I have also been checking the kits to make sure that I have everything and I think I do, I also found that the kits include spare wrappers for the cylinders, clearly Dave was expecting us to have difficulty with this part.
I find that the best way to bend them is to start with the cylinder itself, this gives a bend but it just isn't tight enough
So I'm using some 12mm brass bar to help, as off the cylinder this is what you get
and after bending round the bar you get this.
Then you can put it back on the cylinder frame to start the second bend and then finish it with the bar to get this
So hopefully now this will only take 10 minutes to solder the wrapper onto the frame.
