Who's brake lever guides do you use Adam?
Wagon looks great!
Thanks - I'm trying to find a source of etched brake lever guides that a) don't involve buying all other bits I may or may not use and b) aren't too fiddly to assemble!The one from the Rumney etch for 10' Morton braked wagons (B.114). Yes, I know this is 10' 6". The 9' wb minerals have these too. All sorts of useful bits on those. And thank you, it's scrubbed up quite well, despite PECO. If it ever dries out, I can paint all these soon and catch up with weathering and lettering.
True, however on the hierarchical table of fiddliness, some are fiddler than others (Ambis for example)!In my experience, etched brake lever guides are, by definition, fiddly to assemble.
I decided, years ago, that life is too short and I therefore use cast levers / guides.
John Isherwood.
Hobby Holidays have the 7mm instructions on their links page which should help with working out how to assemble them. Most are obvious once the logic is explained.I like fiddly etched bits too - or I do now I can actually solder them!
I can't even work out how to assemble the Ambis ones!
It makes us contentIt seems that even the Scalefour Society claims that anyone that details anything using a Masokits part is described as a fanatic. I wonder what that makes S4 society members then? LOL!!
Tony
It makes us content
FWIW, I like the Craig Welsh 'stand alone' NS etched brake loops. They came (and are still available) from S4 Stores. The instructions are here
I've described them before as 'pan-dimensional origami' but they do fold up into something neat, and strong (once you've dabbed some solder into the bends.)
Jan
Tony
Another ready for paint. The only detail worth noting are the steps atop the buffers. Parkside give you a couple of bits of moulded plastic but these are fiddly and vulnerable. This arrangement, made from a couple of pieces of scrap etch, are pinned through the buffer stocks and glued in place. Will it be warm/ dry enough?
Sorry - but, unless my eyes deceive me, you have suffered the same 'sag' in the wagon deck / sides that happened to me.
If I were to build another, I'd superglue a 10×3mm. steel spine below the floor.
John Isherwood.
Having just held a steel rule up to it, you're absolutely right - I guess that a bit of differential cooling as the moulding came out of the tool. Now, since the underside of the floor is partially clear, and the deck will be covered with a container, there is something I can do about this... Thanks for pointing it out.
Who would have thought we'd be offered rtr LNWR wagons. I know now't about wagons and so I don't know when the last ones left revenue service.
