O-EM-OO9 workbench - DCC-EX
76043
Spent some time today adding three link couplings to various minerals, more tomorrow.
I requested from Asis3d an EM set of axles for the Bachmann split chassis pannier. A few adjustments and I think I have an EM conversion for that loco using the original wheels. Darker axles/gears are the new one.
Tony
76043
I made this potential baseboard a while back from an abandoned chipboard shelf and picture frame material. The question is what to do with it? I wanted it to be an EM test track/starter layout, it's 90 x 27cm.
Of course one option is to bin it, but I did want to put a lengthened Scalescenes canal wharf scene on it, deleting the canal and adding an extra track, but I reckon this will take ages, so maybe something more rural would be easier? Might be good practice with the static grass?
Any better ideas?
76043
Funnily enough, I was planning on laying cork, so maybe the pin board is an option!
Tony
I was thinking - being chipboard it will start to become a heavy item to be constantly moving around and store.
For a test track I would use a simple shelf, lay some track and practice scenics. I built this 7mm 3rd and 4th rail version on an unused shelf board I had kicking around. In 4mm scale you can incorporate a point and turn it into a simple 'tuning fork' type layout.
76043
Anyone any idea what rivet transfers I could use from the Railtec range for a rivetted tank pannier of the early 77xx variety please?
They have a lot of varieties and I don't have a drawing of a rivetted tank.
Tony
It's a shame Railtec do not produce a sample pack/sheet (of a decent size) of mixed sized and spacing patterns of rivets is the same way Archer used to offer - which were very useful.
Then you could have ordered that to compare with any existing rivets on the loco before committing to the correct sheet
I've noticed it's the British way to produce single sized packs of anything useful like this forcing you to buy more than you need where a mixed size and spacing on a single sheet would suffice. Either it's a deliberate ploy or a lack of logical client friendly thinking.
76043
I saw that my Ian Beattie plans book on GWR locos has the pannier drawn with rivetted tanks. Drawn quite roughly I'd say, but shows a 1mm spacing which may or may not be correct. Looking at the pannier papers it's probably 0.75mm so a ballpark figure can be reached. I'm not counting rivets, just want a rough approximation.
Tony
So having been trained on lathe work at college by an ex-BAE engineer, and using a lathe on subsequent commercial modelmaking jobs, I know my way around a lathe.
I therefore bought a Unimat 1 on eBay, LOL!
For turning 4mm wagon wheels it's just at the right price point for me, a proper unimat or proxxon was just too expensive. I have in mind some other jobs such as smokebox door turnings, in plastic obviously. I don't work steel ever, mostly plastic and brass so this is perfect for me. I will never work in the harder metals.
So first job was to see if I could slim down some Oxford wagon wheels treads to 2.5mm wide for a rough and ready EM project. My Vernier confirmed 2.5mm so that'll do, it's the LNER open that isn't right in the brake gear department, but I say you can only ever view it from one side at a time.
Tony
Tony, what cutting tool did you use?
Tim, I used the supplied lathe tool, was sharp and is branded TCT so seemed ok. I have plenty of lathe tools from my working life, but none small enough to be near the centre as the supplied one.
Tony
cctransuk
Tony
If it's the same as the Unimat-3, you need 6mm. or 1/4" tools.
John Isherwood.
timbowales
John Isherwood.
John, the Unimat 1 is definitely not in any way like the unimat 3 :))
For starters it's made up of alloy sections that the user bolts together to make it up in the configuration you want to use. There is a lot of plastic in the construction. It is also intended to be battery powered although a transformer/rectifier power supply was available.
cctransuk
I was aware of that - I merely thought that the size of the small lathe tools might be common to both.
John Isherwood.
76043
The Unimat 1 generally gets panned universally, probably because people try and do stuff on it you shouldn't do. I mostly want to shave slithers off wheels and do stuff in plastic, so it's right for me. It requires some careful construction and stabilisation.
The lathe tool is 3.5mm thick.
Tony
timbowales
Tony
Tony, that saves me digging out mine to measure them :)
