Herb Garden
Yep she is one of the same batch as 806 mentioned earlier..... Batch of 10 reduced to 8 for the Swedish railways the other two went to the Thetford and watton railway later becoming GER 806 and 807 .....
Yes I'm a geek!
George,It's been a while since I've been able to make any progress. Work, DIY and the fact the west facing room in which I do modelling is like a sauna doesn't help.
It has however given time for pause and reflection. When I started this locomotive I had planned to twist history a bit to extend its lifespan into the 1880s GER blue period.... But recently I've considered a different approach...
It started with the arrival of the boiler fittings. Although I had wanted to turn them, time and a pile of stuff blocking the lathe whist building made me turn to 3DP. Thanks Chris!
On receipt of the prints I found myself drawn to the flared Johnson chimney. I had originally planned to use the later Adams stovepipe but something kept nagging. So I wondered about not modelling the locomotive in 1884 but in 1873?...
So what would that look like? Well for starters the livery would be green....
When Sam Johnson took over at Stratford in 1865 he changed the Sinclair pea green livery to a mid green.... Very like that used on the midland.... Before they went Red. He also experimented with ochre and cream liveries..... Best not to ask.
So in theory If I went to 1973 the livery would approximately look like this...
Although the lining would be white rather than yellow.... How white it stayed is anyone's guess.
The second point I need to consider is the shape of the front
The Johnson GER locos all had a trademark flared front something unique to his time in the east and not carried over to his midland designs but as a design style probs came from the NBR.
That's a little Sharpie #1 class blas built by the way. And why they were called little Sharpies I do not know cos next to an actual Sharpie as in the little spinner That I'm building they are huge
That's a #1 class in the foreground with the #73 class in the rear.
This leads me on to another interesting point the #1 class model in the photo above I inherited a while back and it's only half built but what has been done has been is superb workmanship. It's even built to EM gauge standards so what is not to love?
But what I've noticed recently is that the builder has subtly modified the kit to have the Johnson rather larger Adams style cab. This sets the model squarely in Johnson's time as Adams very quickly improved driver conditions on locos.
So that's another loco to potentially go green....
So what am I thinking? Well as those who saw my posts in the winter will know I have a collection of GER models from the turn of the last century.... But wouldn't it be fun to have another set from 25 years earlier? When you see models of the pre grouping era they are very rarely of a vintage later than 1900 so wouldn't it be cool to do something earlier?
Mucklemouth could be equipped with two fleets.... The 1873 fleet and the 1896 fleet... Wouldn't that be fun? Well I think it would!
Not that I'm going to get too much done over the next few weeks due to this and that but the nice I finally get to the workbench again I will have had a chance to come up with a cunning plan....
Yeah certainly the early type wagons lasted into mix in with the later Holden types in the 1890s.George,
That sounds like an excellent plan! Wagons could probably be shared between the different eras. Carriages?
Nigel
@Crimson Rambler thanks for clarifying. That would mean the schemes under Sam Johnsons times were almost identical in colours if not the lining panels until the GER went black and the blue and the midland went crimson.@Herb Garden - The lining on Midland engines during SWJ's green livery period was normally black and white - yellow and black lining appeared with the red livery. In this respect I'm afraid your colour print is misleading - but fortunately it doesn't apply in your case.
Crimson Rambler
Ooooo very interesting.... Sounds like I need to get a copy of that book.According to Jack Braithwaite in "S W Johnson Midland Railway Locomotive Engineer Artist" (Wyvern Publications 1985) rebuilt Sharpie 222 No 74 was painted "Plum Colour".
Just bought one this morning for 6.42 inc postage..... Not bad.....It's this one:-
fleabay link
Not mine and there are others available.
There are only a couple of pages on his GE work but the rest of it is filled with photos of his Midland locos, well worth it if you can get it for less than a Tenner (my copy is NOT for sale).
