Unfitted Project: LMS variations
And then three more. The most numerous pre-Nationalisation wagon design and its cousin. I'm making two of the former - LMS diagram 1666 - from the Cambrian kit, with modifications. This was a 9' wheelbase 17' 6" over headstocks unfitted open with independent brakes and the LMS built some 55,000 of the things from 1923 onwards: every post-Grouping layout should probably have one or two.
The internal planks are represented by raised lines and I've replaced the ends on this one, along with the headstocks. Nothing wrong with the kit ends, but since I was scribing sides and ends for another wagon and had some strip left over I used some of that. What of the other wagon? A rarer bird, but a similar type. Diagram 1895 was quite varied: the 1200 wagons in three lots, one with double brakes and two more with Morton brakes. Mine is one of the latter, based on a Ratio underframe with the steel solebar infilled to represent the real wagon's wooden underframe. The latter is a bit odd as the LMS wasn't really building all wood vehicles by the mid-30s, but is makes an interesting variation, along with the barrow plank on the doors.
), as - having spent a bit of time looking for them on Flickr last night - they are as ubiquitous as the raw figures suggest. I was slightly surprised in the same trawl how common the LNER equivalent was: I should probably build another one of those.
) layout can accommodate all of them.
