Pannier Tank
Thinking ahead to a Dapol Class 22 Gauge conversion where I will be re-using the Plastic Gear Wheel on replacement extended Axles. The Gear Wheel is a push fit on the Axle and I am concerned that this may slip when in use. I am not too sure on what adhesive to use, Super Glue may set too quickly before the axle is in position, Araldite maybe too thick and some of the Loctite Retainers expand when applied to Steel and therefore could possibly split the Plastic Gear Wheel.
Can anyone recommend a suitable adhesive?
