Lyndhurstman
Now that is nice.
Perhaps tinning the relevant shank with as little solder as you can an a light polish? You could gain the odd micron of additional clearance by means of a bit of gentle broach twiddling in the shank. Worth a go?
Hi Adam,
Thanks! Yes; I was thinking some solder might work, but as I have 24 of these little blighters to do, I'm still trying to find a process that minimises effort and maximises enjoyment - and learning
Hence the wonder regarding plating with NS. There appear to be several YT videos and fora that describe the method, but I'll not make a move into Electric Plating Land (cue Jimmy Hendrix..) until I’m convinced I can do it in safety! As to broaches - again, it's a potential source of fitting freedom... all good stuff to chew over...Interestingly, in my search for stuff, I came across this:
In the deep and very distant past I remember being toldt,on a school trip around "The Works " at Wolverton that the standards for BR plating was for nickel , copper then nickel , inspection , 2nd Nickel . For Chrome , copper , Nickel , Chrome , inspection, 2nd hrome. Could explain why the handles on 60yr old coaches still have chome on them !
Nickel Plating Brass | Model Engineer
Thanks again
Jan
). A few seconds of back and forth is all that’s needed. Any burrs (there will be some) are dealt with using a Swiss file, and the bore cleaned up with a suitable broach. Now it’s just a matter of finding a nice thin glue to hold them in the plastic housing.
I suppose a lump of casting was too much to accommodate in such a modern design! Still, even at this late stage, it’s the little discoveries like this that give me pleasure..
