I took delivery of a Slaters 28xx a few weeks back, When it arrived I tested it and it runs very smooth. The previous owner completely rebuilt the chassis with full compensation. The loco was a little rough though so it was submerged in a bath of detol! The fire box came apart which was a good thing as I could put it back together square! Additional detail was added using parts from JLTRT ( lamp irons, ATC shoe, sand filler lids, boiler band straps, vac pipes and cylinder castings ), Warren Shepherd ( steam Lance cock & smoke box door dart ) Malcolm Mitchell mud hole covers. I just need to get some new couplings for the loco. The tender was fine and had just had new Fox crests, cast lifting rings and Vac pipes added.
The smoke box saddle was given a good clean up as well as the all the flashing was still around the bolt heads. All the gaps between the firebox sections where filled with car body filler and rubbed down smooth. Halfords primer and satin black paint to finish. Just waiting on the Severn mill plates to arrive and cab side route availability transfers and pop the back head back in. This will need a good weathering plus some nice crew from ModelU.
Not forgetting some red paint for the buffer beam.
