Len Cattley
Hi Mick, I'm in the same boat as you. The only alternative for me is to buy the kits then CAD the chassis and other bits that I need.
Len
Len
The other alternative is just to accept all the errors, build as such and just get on with it.
Your desire to build as accurate a model as you can is an entirely laudable ambition. You have my admiration in that ambition, as it is one I think we all aspire to to some degree.
As you have probably begun to realise, you may have to rein in that ambition to quite a degree - especially if you hope to have some completed models before the end of the century!
Don't forget all railway modelling has varying levels of compromise. You have to decide which areas you are willing to compromise in order to achieve finished and working models. If you don't make that choice, you are increasing the likelihood of shelf queens rather than completed models. I have more than enough of those, and I'm beginning to realise some of them may never see completion unless I make some hefty compromises!
(I am thinking of a particular Fowler dock tank, for example. The box has been a shelf queen for some considerable time, but I'm beginning to think I ought to spend some of the time I would otherwise be spending building for clients in order to make some more real progress with it.)
It is the art of compromise in our hobby which perhaps is the hardest to acquire. While the rest of us can advise from our own experiences, it's your choice in the end.
and finally a look in the box at the ashpan and lower firebox bits and see what's needed to close off that area under the footplate.Take a piece of half-hard 1/8" square balsa, cut end square, attach nut to end of balsa and fiddle away. There are a couple of methods of securing the nut to the balsa:-Way down there is the bolt for fixing the cone and parallel parts together, try as I might I failed miserably to get the nut on no matter what sort of implement, special or otherwise was used, until, I stuck it to my finger with double sided tape.
Don't know what all the fuss was about LOLSee, I knew you'd get there![]()
Put knife split in balsa to trap nut,Take a piece of half-hard 1/8" square balsa, cut end square, attach nut to end of balsa and fiddle away. There are a couple of methods of securing the nut to the balsa:-
* chamfer end of balsa and impale nut on end;
* blob of blu-tak on end of rod, press onto nnut;
* smear of UHU on end of balsa, press nut on end;
* double sided ticky tape on end of balsa.
regards, Graham
Maybe, but to add a near scale diameter tube plate will require that face plate to be removed or thinned even more to accept an under scale diameter one, I've already gone two steps backward with the cone section of the boiler and splashers, by mis-cutting the splasher tops, so new splashers required later today with the correct cut out once the hole in the boiler cone is filled. I'm not discounting it, just not rushing into that area just yetThat big hole in the smoke-box cries out for detail![]()
That'd work, except the access is angled and a straight run at the nut isn't possible, ergo finger and sticky tapeTake a piece of half-hard 1/8" square balsa, cut end square, attach nut to end of balsa and fiddle away. There are a couple of methods of securing the nut to the balsa:-
regards, Graham
These are only temporary fixings as once the seam is soldered then the nuts and bolts will be removed...I need them elsewhere. I could of soldered the nuts onto one face, but again the angled access precludes the use of a screwdriver, and as noted above I need the bits elsewhere.
the parallel / cone join should line up with the intermediate splasher joint with the footplate and the front face should line up with the valve cover and outside cylinder mounting flange. The end result is that a 1 mm segment will be inserted between the firebox and cone section of the boiler, this leaves more of a gap to fit a correctly formed firebox front, the castings of which seem to have vanished from the kit....probably the previous owner.
