3 LINK
Good afternoon Guys,
I thought rather than clog up my Church Norton thread, I would start a new thread regarding the above title. I will start of with the method I am toying around with at the moment. There are many tried and tested methods of making the main tree trunks and branches, and most are very time consuming to create, especially so if you intend to make a wooded area. So I have cheated and gone for the ready made type, see below. They come flat packed and can be twisted into whatever shape you want to achieve, even the windswept one sided look. The only alteration I make is to cut off the locating sprue, drill out the base and replace with a panel pin. Most of my landscape is built using Celotex foam, so this makes it easy to plant the trees wherever fits the bill.
More to come later,
Martyn.
More to come later,
Martyn.
