After thinking about the brake gear some more, I decided the sensible thing to do would be to make the chassis and brake assembly one unit, rather than trying to keep them separate. The only downside of that decision would be that the body would require amendment, it being the both the reference and mounting points for all of the brake parts.
Whilst mulling over that choice and deciding the best way to do that, the primed footboards were tried back in position. I ended up running a 1.1mm drill through the existing holes to get a nice fit, tight, but loose enough so as not damage anything during removal / assembly.
Decision made, all brake mounting points to come off the body.
I measured everything up, wrote the relevant positions all over the instructions and broke out the dremel and a die grinding bit. Working on one corner at a time, and cleaning up straight afterwards, kept the mess down to something acceptable.
Brake mounting blocks on the left hand side gone and some of the sand pipe mount removed
Another half an hour and its all gone back to basics.
With the body mods done it was time to fabricate the replacement brake cross shaft mounts. The original Vee hangers were reused, just soldered together to make a thicker unit. Working off some drawings Mike sent me, I made a new hanger for the other end of the cross shaft - its just a single mount that hangs down from one of the cross members, although I copied the fact that it is made in two parts to aid removing the shaft.
The other bits for the shaft were fabricated up next, including the pull rods that actuate the whole assembly. From left to right we have:
Shaft end mount, spacer, double ended yoke for brake pullrods (it sits on the centre line of the van), another spacer, actuating lever (above that the pull rod assembly) and a final spacer to sit up against the vee hanger. Underneath is the basic cross shaft - this has been counterbored at one end to take a 1mm piece of rod to go through the vee hanger, I think I will probably drill and tap the other end when it has been cut to length.
Mocking it all up in the modified chassis
And the last shot showing the brass bar additions to the basic chassis frame.
The brass bars finish in a position that allows me to hang a bracket off them for the brake shoes whilst still clearing the backs of the buffer rams. The brass cross brace shows the fixing methods for the actuating pullrods and the new shaft mount, just a dab of solder on each one will keep them in place.
Brackets (and no doubt more rust removal) tomorrow.
Steve
