Time to stop playing trains and return to this ongoing project.......... so where was I ?
So far she runs through a B6 turnout with no front bogie problems but then the springs are not fully supressed yet
With all the details and gubbins between frames I`m not going to be able to apply my preferred choice of pickups....... so there is only one option for me and that is to use sprung pickups.
I`ve never really got on with them but I`ve decided to try Slaters having read Jim McGeown`s advice on them.....
Nice... but I was`nt happy with the springs which seem either too short or the hole in the housing is too deep. Either way they seem far too weak to provide strong enough contact on the rear of the wheel tread , especially after adding the pickup wiring as the springs are not strong enough to overcome any pull they might impart.......
So I decided to carefully pull the springs on the plunger shafts to make them at least as long as the non threaded part of the plunger shank
This has made me more confident about their effectiveness..........
As you can see.... the lower of these two is just the spring as provided, whereby there is no strenght to the spring until it is flush with the face of the housing. The upper is after fettling the spring length.
Overall I`ve now got a working set of four as I`m only going to apply to two driven axles with two tender axles using my preferred system.
Now to drill the holes in the chassis frames................
