Is it the end of the days work, the coach is left stabled in the station over night, loco off to servicing, fresh loco back in the morning ?If what we can see is the coach and engine from an auto-service... then why is the engine uncoupled from the coach? What a pity that the lineside cabinet is in just the wrong place so that we cannot see the coach couplings and electrical connections to the engine.
regards, Graham
(touche!!)
Why rivets as well as chairs? Whitemetal chairs would be perfectly strong enough, and you could glue them down.Well, progress has stalled, and the main problem is trackwork, the resin chairs are not sufficiently robust, it looks as if the best/only solutions are some sort of plastic moulding, which is going to be expensive, or w/m chairs and rivets.
You are a froth merchant and I claim my £5.Im undecided how to proceed although a piece of 8x4 chipboard and Blue Pullman could be an option!
Well, progress has stalled, and the main problem is trackwork, the resin chairs are not sufficiently robust, it looks as if the best/only solutions are some sort of plastic moulding, which is going to be expensive, or w/m chairs and rivets. Im undecided how to proceed although a piece of 8x4 chipboard and Blue Pullman could be an option!
That might work. I think they would cast better in two parts, but then its a right faff making track.Thats the ticket! When all else fails, revert back to the roundy roundy LOL, its simplistic format is oft under-rated in the 'fun' scale . The modern ultra detail modelling often practiced and touted as the 'only' form of model railway modelling, will never replicate those innocent childhood days of a circle of track to whizz trains round at lunatic speeds , faster if you super elevated the curves with matches under the outer edge of the sleepers!
Go on, you know you want that Blue Pullman LOL.
Re resin chairs, is it possible to use a pin to solder the rail too and then add the chair later? I.E. by cutting the resin chair in half and glueing it back once the rail is soldered to the pin. You wouldn't have to do every chair, perhaps just every 5th or so, the others could be slid on and simply glued in place, the strength coming from the solder tacked ones. Agreed it's a bit more faffing around but could allow you to use those super CAD designed ones you have developed.
Kindest
Are they going ahead with it ? .... I though the idea was shelved (Westdale do a complete set for about £700 though)I believe PW has been doing one.....
I believe so.Are they going ahead with it ? .... I though the idea was shelved (Westdale do a complete set for about £700 though)
No I haven't tried them. I suppose I could butcher them and remove the bolts....I kind of share your frustration Cynric, the Gauge One thing is a real uphill struggle when you are trying to do it properly.
One thought about your track, have you seen/handled/got any of Cliff Barkers moulded BR 3 bolt chairs?
If you haven't then I'll send you some to play with, although to 10mm scale I think you'd like them.
The rail inclination is correct too
I believe so.
No i haven't . We need injection moulded GWR chairs and decent wheels with moulded backs. I have a nice pair of ultrascale P4 wheels on the bench and they have the rear recess mouldedHave you actually held any?
I made a small section of track with them where I reduced the base and stuck on a key "tail", I think for what you are doing this would work well. I don't think that any of the G1 whitemetal offerings have the finesse that you will be looking for.
It's another absolutely "glaring gap" in what's available in G1, even today people are still using Tenmille - don't ask me why
