There is now a gate across the steps leading to the locker room...
All will come to pass, because I take all suggestions on board and act on them ~ eventually.Just noticed the coal scuttle on the verandah. If you're brave - drilling out the top will improve it's appearance. Or alternatively - in the immortal words of the Rolling Stones - paint it black.
Blame the live frogs...
Regarding large later cut roofs, I recommend gluing them to the building before applying the laser cut card slates so that they won't warp.
Hi Graham. It would not have warped had it been glued down before the slates were added. Initially it could be bent back because it was still malleable, but the weeks and months passed by before I painted it and so the roof was like a bone.I'm sure you already know, will you be placing a similar material underneath the laser material to counteract the possibility of warping Larry ?
I'm at a similar stage of thought with my scratch build goods shed and slept on it ( the thought that is ! ) last night.
I wish you well with the rebuild if you're not satisfied but knowing your perseverance you'll get there.
Grahame
