Yes, they definitely demand a different technique. I’ve puddled enamels for ages to get the look I’m trying to achieve, and translucency, darker corners & crevices, etc, are all do-able as you note. I’m not too bothered about using the thinners and a brush indoors, but I like to air-brush too, and that’s a non-starter using enamels in the house. It stinks.
I’m going to persevere with the acrylics, I’ve seen some exquisite models painted with them, so I guess it’s just a case of learning.
Simon - why not have a go at underpainting the corners in a darker colour before applying the top coat so when applying weathering washes the corners will darken further. When using Vallejo model colour paints for washes I've found a brushful of Tamiya acrylic thinners in the paint/water wash mix is far better than using the Vallejo acrylic thinners.
I'm beginning to use the underpainting technique more frequently before applying top coats to achieve an effect I'm after. After all, if underpainting was good enough for the 17th century Dutch masters then it's good enough for me.
