Fraser, I agree with your observation... let us not forget the "coupling" options in the CPL Products range see here.Have you considered using closer to scale coupling hooks? Ambis do a range in 7mm and I think the same in 4mm. Slaters do some nice scale 3 link couplings in 4mm but they wouldn't suit this one.
The coupling hooks do look a bit big, they are all I had to hand and I'm also not too good at using 3 links so they are easier to use. I plan on smaller ones on any locos I use.Looks good. Have you considered using closer to scale coupling hooks? Ambis do a range in 7mm and I think the same in 4mm. Slaters do some nice scale 3 link couplings in 4mm but they wouldn't suit this one.
Thank you.Looks excellent to me!
With the Hornby 21T hoppers, the body is very easy to separate from the underframe moulding, it just clips in place. I always separate mine and remove the wheels and give the u/frame a waft over with Tamiya TS62 or 69 from a rattle can. This gives a suitable base coat for further weathering with Lifecolor/Vallejo paints.
These are not hoppers but it shows the idea!
Cheer from Oz,
Peter C.
Steve, I spray the wheels with Tamiya TS1 first, then add rust highlights when they are back in the u/frame with Vallejo rust.Thanks Peter, do you paint the wheels using the same colour?
Def not 7mm Tony, I cant say I'm not tempted by some of the models available now though!There’s a couple of weird things going on here:
1) Hornby don’t do 7mm hoppers
2) You have huge thumbs
Or maybe this really is 4mm modelling…..
Hi @steve50View attachment 162074View attachment 162075
I've airbrushed the underframes using frame dirt as a base for further weathering, I've also got some AK weathering pencils so I might add a few marks somewhere just to try them out.
Thanks Jan, I know there's a lot more I could do in the way of detailing, I've still got to represent the levers and rails on the ends.Hi @steve50
These are REALLY lovely. I particularly like the chipped paintwork on the first example. Now, about those chunky brake levers...
Jan
Lovely work!
Any more photos of the layout they appear on?
I'm a big fan of Smiths coupling hooks, despite them being overscale.The coupling hooks do look a bit big, they are all I had to hand and I'm also not too good at using 3 links so they are easier to use.
