iploffy
OC Blue Brigade
What radius did you use on the inside Ian? Was it the 6ft with the tremmel to set the outer loop?
Mark the inside loop is 6ft and the outer one was tremelled from that. As you can see from the pictures the loop has arrived in the station area in roughly the original location, the Up line(next to the fence) will have to come at an angle to give the correct geometry for the South end of the long loop, so Dudley Port Stn will have to be slightly disfigured and not as it is in real life. Ho Hum so be it. My next move is to pack up the inclines as the one we did is a little bit on the springy side, no problem mastic underneath and push down till a uniform incline is produced.
Now we move on to the shed, what a bugger that is going to be. Where the wood from the shed wall is fixed to the framing for the supports holding the ply, I can see that the formation is tight and definitely not level, that is going to take some thought.
