Richard Gawler
Hello from Essex
I have been modelling in 0 gauge for less than a year. Last summer I bought a Minerva Manning Wardle K class loco. The idea at the time was to put it on a low loader and to build a 7 mm street scene to show off a rather lovely row of shops I was able to buy from the estate of a modeller who had bought commissions from Allan Downes. Who in turn inspired me a lot when I was modelling in my teens about 40 years ago.
Well, I just sort of looked at this model for a month or so. Put it under a Perspex cover and admired it. I had a look for a suitable “heavy haul” tractor in the diecast ranges and found nothing, and ended up just buying two yards of track and a couple of Dapol wagons as a sort of a fix. I discovered Peco BH rail uses their FB rail joiners. Then I realised the loco ran perfectly out of its box and ran better than most of my 16.5mm gauge models, and I enjoyed this so much I bought a Setrack point and a third yard of track and built a simple baseboard for a little test track.
Well the big mistake I made was to buy two wagons and to keep them near each other without a trip to the vet. Nature seems to have taken its natural course now I have four more RTR wagons and I am doing my ninth kit-built one. I have joined the North East Essex group of the Guild, and now signed up to Western Thunderer. Both seem like friendly places to share new models and ideas and progress and so on.
As a beginner in 7mm scale I may well not have much new knowledge to contribute here, but I am hoping to model a railway set in the 1890s; this is a relatively unpopular period and so maybe I can be useful here. I do know, I have given up on the idea of the low loader
Contents
1. Wagons from plastic and MDF kits: a drop-side wagon, Chas Roberts tar wagon, NBR box van, MWR brake
2. Wagons from metal kits: chaldron wagon, GER low machinery wagon (LNER Lomac-L), tender truck
3. NBR 'Jubilee' coal wagon
4. GWR 'Hydra' wagon for carrying road vehicles, plus discussion of early 'Jubilee' wagons
5. Running qualities of the Hydra (and Lomac-L) on Peco Setrack, GWR 4-plank wagon
6. GWR 4-plank wagon (continued), 'Railway Wagon Technology', Manning Wardle 'Blackwater', loco 'Nellie' including chassis ideas and crane jib
7. First assemblies (crane jib, chassis and smokebox) for 'Nellie', discussion of supplier Branchlines, arrival of LNER Y7 ' 8089'
8. Chassis of Y7, start of crane tank 'Nellie' including initial design of chassis and balancing
9. 'Nellie' especially development of chassis
10. 'Nellie' including early chassis conclusions, cab detailing, adding the boiler and smokebox, and the plunger pick-ups
11. 'Nellie' chassis reassembly, hand rails and whistle
12. 'Nellie' cab interior, cab roof, drawgear; and Nellie hauling part of 'The Elizabethan'
13. 'Nellie' loco performance and final construction including boiler fittings and brake gear
14. Notes on Halford's enamel paint, subassemblies of 'Nellie', station platform shelter, Nellie with a service train, new buffers, I&WEMRC
15. Compact tar wagon, GWR 4-plank wagon (and a box of Vallejo paints), ex-MR box van
16. Assessment of the GWR 4-plank wagon, ex-MR box van (continued) with O-level metalwork
17. Ex-MR box van (continued), notes on forming styrene, "annual report", left-hand B-6 turnout, notes on GWR 4-plank wagon
18. Left-hand B-6 turnout, first plan for a layout, right-hand A-6 turnout, GWR Hydra painted, GER Y14
19. GER Y14 - a baseline for the loco and its S23 tender, and assembly of the tender body
20. S23 tender footplate including outside frames and running gear
21. S23 tender chassis completed, radio control installation, baseline for loco, tender test running
22. Thoughts on DCC and sound, Y14 loco chassis, discussion of wheels for future models
23. Y14 chassis - trial runs, and discussion of wheels and crank pins
24. Y14 chassis - trial runs, correction to A6 turnout
25. Y14 chassis trial runs, superstructure
26. Y14 superstructure: smokebox, splashers, firebox
27. Y14 superstructure: second smokebox, boiler & firebox assembly, detail parts, plywood platform for ballast weights
28. Y14 test run with superstructure; lubricator, blower valve and smokebox door
29. Y14 cab fall plate and steps, clack valves, loco completed for painting
30. S23 tender axleboxes, springs, footplate, brake standard, rear hand rails, tool box, water filler; a scenic loco boiler
31. S23 tender and Y14 cab hand rails
32. Scenic loco boiler - especially reworking the tube plate
33. Scenic loco boiler, 4-wheel coach, 'Nellie' visits the Middy
34. “Heybridge, an Essex Idyll” (the back story), break van refurbishment - wheels
35. Notes on rust and tarnish, break van refurbishment - roof, light delivery horse, scenic loco boiler
36. Oil engine, 'Blackwater' visits Taw Magna, painting model people
37. Painting highlights and shadows, crankpin problem on 'Blackwater', Y14 retrieved from painter
38. Quartering problem on 'Blackwater'
39. Y14 & S23 final assembly
40. Baseboards and their dowels, Gloucester 5-plank wagon, horse 'Charlie' painted
41. Model people and period clothing, GER 10-ton van
42. GER 10-ton van, 4-wheel saloon
43. Coach lighting especially oil lamps
44. Coach lighting (more)
45. Trimmings for GER box van and Y14, new brake gear on a Dapol RCH wagon
46. Baseboard height, Y14 visits Chadwell Heath, end of Year 2
46 to 59. Manning Wardle class F (introduction and contents list)
60 to 61. 0-4-0T 'River Pant'
61. A Sample of FB Track
63. Baseboard Datum
64. MR fitted van
Related topics
A private coach in the 1890s
Heybridge Basin (first part of a layout)
Small traverser with added vertical movements (abandoned design for a layout)
Using a R/C loco as the power plant for a small 0 gauge layout
Women are difficult (railway passengers 1889 to 1907)
Contents
63. Baseboard Datum
64. MR fitted van
Related topics
