I really need to have a clear out around the workbench ! Dare I start though?
Meantime, here are a few pics of the carriage from before Peterborough and Albury. Putting them up now will at least enable me to start clearing the laptop...?!
The interior planking detail is very fine - perhaps slightly too much so in this case ? The partition and ends on this kit represent those of Third and Second class vehicles. They were Deal tongue and groove planked, painted and Light Oak grained on the originals.
I ended up highlighting by scribing all the horizontal joints with a 4H pencil before applying any finish.
Ends and partitions are also triple layered, with optional cut-out sections on the inner to allow customers the choice between quick, rigidly fixed or fully working, slidey doors.
The sides are similarly treated, so that with a bit of fiddly care, the droplights can be made to drop as well...!
Guess which options I prefer...??
There were only a couple of minor misses that slipped through the net: - A short stepped section on the joint edge of the balconies to form outer door thresholds were forgotten in the grand plans, leaving an embarrassing daylight gap, as well as very overly flappy sliders!
Of course, only noticed after gluing up the assemblies, the problem was easily remedied (and disguised for the show) by a pair of narrow strips cut from the waste fret of the outer skins. Once dropped and glued in place, the slightly raised lip thus created could possibly be preferable to a plain engraved line, but that's how it will have to be?!
The tab pockets and stanchion 'oles on the ends are covered later by a margin board.
Now for the naughty, compromise part:
Needs must, and all that...?
I'm afraid that these days we are faced with three choices in this field? Go for an all singing, all dancing, no holds barred, top of the range job; Cheap and cheerful - reasonably so anyway, or just give up and not bother at all in the face of plastic, straight out of the box and play...?
The cost of producing some handsome castings for the axleguards was unfortunately considered unjustifiable. Besides that, the competition seem to be merrily going the same way in 16mm?
Mmm, I really don't like it at all.
Integral, laser cut plywood W irons and axleboxes ? Once the wheels are fitted they become horribly permanent - an absolute wotnit if damaged in any way..? What about oil eh?! Garden railway, live steam hauled stock tends to get drenched in the stuff...!
The scale of this carriage is admittedly a bit cheeky. 40mm diameter, split spoke wheels running on 53mm (for Malta) or 56mm gauge track (New Zealand) would be correct for this stock, but none are either available, nor practical. 32mm being the common choice over 45, which latter might be just about acceptable, determines the order of the day!
I decided that the pinch and permanence was a step too far, so set the solebars in the 45mm slots, and then rigged a simple steel lash-up for the bearings!
The carriage could then be displayed on the Brandbright stand, occupying the same set of rails as a Roundhouse "Lady Anne" as well as any other rolling stock for comparison.
View attachment 103182View attachment 103188
I am still happy to forgive the forced errors though - especially as the body has turned out to be a nicely delicate, and indeed fine representation of the prototype.
More later...
Pete.
