I'd appreciate that. The drawing is to scale. The distance between the lines is 33mm and the orange is the centre line on the full size for 7mm attached.Phil
I should be able to do that, but I need to what the radius is going to be and the maximum limit for the baseboard size etc.
ok, I've got the track plan into Templot and laid a small section. Now the hard part...
Yeah, it was a brexitup with the dxf import.It doesn't look too bad. Is that a Barry slip at 2700,450?
Jim.
Love it!Yeah, it was a brexitup with the dxf import.
It looks like you are managing just fine on your Phil.
What is the minimum radius coming out at ?
Its frustrating and strangely satisfying at the same time....Phil,
Templot is a bit like that, you bang your head on the wall for hours then suddenly pennies drop and clicks do what you thought they would.
Hang in there, it’ll happen in a minute, or two...
Best
Well, after several hours and many redo's I've done very little....
Trying to work out transitional curves and how does one join track between two existing pieces??? and three ways??
I made a crossing but still not sure why I have missing rails...
No sympathy required and as with any computer package a learning curve is required. I’ve found Templot to be no different but does have the added complexity of necessarily having many terms that are not intuitively obvious. So a little more effort is required to learn and for myself at least, to relearn every time I come back to it.Hi Phil,
I don't have a lot of sympathy. On the download page, and the front page of the Templot Club forum is this message:
One of the reasons I get so downhearted about spending hours and hours on the docs and videos is that I know so many folks simply won't read them. I often feel like giving up.
If you had started off learning Templot on a simple branch terminus as an exercise, you would find it so much easier to create your intended layout plan afterwards.
Linking between existing templates: link between existing templates
3-way turnouts: 3-way tandem turnouts
I have recently written this temporary page as a sort of reminder of what Templot is about and how it is intended to work: 99. origins, methods and intent
cheers,
Martin.
Hi Phil,I’m actually pretty pleased how I’m getting on and I’m enjoying the process.
I did find that the video links are broken. Are these out of date now or is that a genuine bug?
is there a ‘New’ button option for starting a fresh plan?
