garethashenden
I've become dissatisfied with my layout Queensbridge. It seemed like a good idea when I started, but it no longer fits my desires for a layout, from either an operational or realism point of view. I have found the space to make an L shaped layout with a double track mainline with fiddleyards at either end, 8'x5' scenic area.
The basic idea and what I want out of the layout are as follows. North London Railway between 1900 and 1905 modeled in P4. A double track line capable of running passenger service, complete with signaling. A goods yard, maybe just a coal yard, but goods traffic would be nice too. Part of a station at one end.
What I have done so far is to take the signaling diagram for Hampstead Heath and curve it to fit the available space. This has the advantage over something I made up of probably being correct! The downside is that it leaves the back corner of the layout needing a lot of terraced houses. Here is that plan:
The other option is to fill the back corner of the layout with a gasworks. That would give me an online industry and a place for 0-4-0s to play. I need some help with the track plan of this though. I'm picturing an exchange siding, somewhere coal gets unloaded, maybe a tiny engine shed if I'm lucky. Some gasworks had internal narrow gauge lines, I think that's complicating things a bit too much. Some of this has been sketched in pencil on the Hampstead track plan. I'm ok with one track going into the fiddleyard, but I want to limit it to that. I think most of the actual gasworks would be low relief or on the backscene. Here is what I have so far:
