I have a soft spot for Victorian era locos, including this loco. When I saw it at Guilford show on the Roxey stand for less than £200 I thought "why not", "that looks good value for money", I could have thought "inexpensive" or "cheap". Cheap is what it is. It's nowhere near the quality of ABS wagons or even DJH locos, both of which I've built.
The kit is mostly white metal with a NS chassis. I followed the instructions and started with the cab. The footplate was flimsy and bendy at the splasher with the white metal thin on one splasher, so care was needed. I cleaned up and tack soldered the pieces together. Not square nor true. I won't bore you with the details, but the footplate turned out to be askew in the horizontal plane. So very carefully I laid it on a flat plate and pushed it true. The cab was again tacked together and was OK, apart from the spectacle plates wrong. With the footplate being so flimsy I decided to build the chassis and mount the part built body to give it support.
The chassis consists of four parts, the two side frames and two small top plates to hold the frames apart. Stiff it isn't, square it wasn't. After tweaking it square and true I put the body on, then the problems really started. Again I won't bore you but the problem was that the white metal has a lot of give in it and the cab didn't fit vertical due to the body mounts bending, then the flimsy splasher base broke
![Mad :mad: :mad:](/styles/default/xenforo/smilies/mad.png)
![Rant :rant: :rant:](/styles/default/xenforo/smilies/stomp.gif)
. Fortunately there wasn't a window close or that might have been the end of this build.
I persevered, mounted the smoke box, again not square, 0.5mm wider on the right than the left and a gap at the back when it was vertical. Got the boiler on and after a lot of fiddling tacked everything nice and square. Fitted the splasher tops and filled in the inevitable holes. I ended up using 144C and 100C solder to get the solder to properly adhere to the brass boiler and the white metal. This has taken a couple of minutes to write, it took about 3 days and high blood pressure to get to this point. Any how, the build is now square and true in all directions, just not very pretty yet.
In my defence, when you look at the photos please note that I can build locos. I documented my build of an MOK 9f, there are photos online of a Roxey GWR MMT in Dean livery that I built. I'm not in the same league as Mickoo or Nick Dunhill, but this build shows my laughable skills in a very poor light.
I was going to compensate the chassis but there is precious little clearance between the splashers and the wheels so I've decided to have the driving wheels fixed. If you look you'll note the coupling rods are in the correct position ref the body. This is because I've lifted the body 38thou with shims at the mounting points
I don't have access to all my kit, so more cleaning up will have to wait until I get home.
Next I shall continue to battle with the body.
Kev
