Homemade spanners using Cap screws
michael mott
Earlier while working on my Air loco I came up with an idea to use a cap screw to make an open ended wrench, I was delighted and pleased to see that I was not the only one to think of this idea, there is a great article in the winter issue of the Gauge one newsletter issue 272 on page 43 by Ralph Bagnall-Wild about how to make these miniature wrenches with some nice photos of the results, with a table showing equivalences for the BA screw sizes.
So I hope that this is useful for the folk working in the larger scale 1/32 and G3
Michael
oldravendale
Thank you Michael. I've been following this thread with a mixture of amazement and enjoyment. Your lateral thinking is amazing to those of us who don't share that ability.
However, what's a cap screw? I'm having difficulty in imagining it and therefore how to convert it in to a wrench.
Brian
Rob Pulham
For those of us working in 7mm Markits do a nice set of BA nut Spinners
NUTSPINNER: BA Nut Spinners (set of 6) - Wizard Models Limited
The link is to Wizard models which was the first that I found in a quick search but I am sure that I bought my set from Eileens at a show - Mike's method is much cheaper of course...
Rob Pulham
Rob, what is the fit to actual nuts or hex head bolts?
Sorry Graham,
I am not sure what you are asking. Do you mean how close to a 12ba nut/hex head does the 12 ba size fit (for example)? If so then a close sliding fit.
I use them quite a bit and each of the sizes fits the nut that it's supposed to assuming that the heads are regular (I have had some odd sized nuts with an 8ba thread in one kit, it really threw me until I worked it out.) I only have 12 and 14 ba Hex headed bolts so can't say for the other sizes but the relevant nuts seem to fit fine.
