I thought the buffer had three fins when I saw the first photo as the upper fin appears vertical while the side one is at an angle rather than horizontal, but I am not sure. Is the top fin wider to form a step?Looking closely at some of the feedback and info that has been supplied I am now questioning the number of fins. The Tatlow drawing shows top and bottom plus left and right but the images don’t seem to bear this out. There is not a horizontal fin showing.
I am now wondering if there were 3 fins rather than 4.
Any thoughts?
Looking the part Simon. I think the suggestion about the fins in the diagonal corners must be correct.Top two & fourth pix in Rob's post suggest 4 at 45 degrees
how's this?
the hole in the middle is wrong but I can soon fix that to suit the shank of the buffer
thoughts?
atb
90 degrees?Top two & fourth pix in Rob's post suggest 4 at 45 degrees
how's this?
thoughts?
atb
<OCD mode>
Well, to one another, yes, but 45 degrees to horizontal or vertical.90 degrees?
Is the PCD of the bolts taken from a drawing dimension? If not, it looks like it could increase by 1/4".Andy, the nuts are smaller, the washers are 7/8” dia. Bigger wouldn’t fit…
3 fins would be inconvenient to cast, whereas 4 fins make for an easier life for both patternmaker and foundryman.I am now wondering if there were 3 fins rather than 4.
Any thoughts?
<OCD mode>
Given the age of the wagon, would it not have pre-war sized nuts? These look a bit as though they are on wartime rations!
Assuming they are 3/4" bolts, the nuts should be 1.3" A/F
</OCD mode>
Only if cast horizontally. The ring on the outer end of the buffer stock was usually a separate wrought iron piece shrunk on after casting to add strength. It is just as easy to cast 3 fins as 4 with the cavity vertical in the sand. 3 fin/rib buffers were quite common, as were buffers with the ribs at odd angles.3 fins would be inconvenient to cast, whereas 4 fins make for an easier life for both patternmaker and foundryman.
These are circa 1860 3 rib buffers (note 3 bolts) made by Bray Waddington in Leeds.
EDIT: to add a drawing from Patternmaking by LL Cox, Pitman 1952, showing a similar buffer type shape set up to be cast vertically.
