lancer1027
Also Heather where did you get the "dynamo " chain ?.
Rob
Rob
If i may ask you a question, who's transfers have you used for the C1 Restriction's ?
Rob
Hi Heather,
I was having a look through your photostream and amongst the very tasty subjects is a D16 build by Laurie Griffin, you don't happen to know which kit is was from do you?
White Ensign Models https://www.whiteensignmodels.com/c/Scale Nuts Bolts Chains/24/1/
Id go for the 11 per cm, the 16 is quite fragile, and 6 per cm is a little crudeCynric, which size would be appropriate??
The window frames have a serious presence... how might the heavy nature of the frames be reduced?
Humm, much as I expected. Thank you.
I'm afraid we come back to the same point again - the best way of reproducing sheet metal is with sheet metal!
Hasn't Tom or someone here already done this, I'm sure his MK2 had etched window frames, maybe his are the later pressurised ones with no top lights now I think about it?Would you consider suitable etched replacement windows for the JLTRT Mk2s, David? The thick frames and afterthought ventilators spoil an otherwise good kit, to my mind.
Actually, looking at the Mk2 photos above, shouldn't there be three dividers in the top light windows? And a vent between the two dividers on the toilet windows for the open coach?
How many you might build is one consideration. Members of the S7 Group who are members of WT seem to be developing a self-help ethos with the added ingredient of "who else needs some?". I acknowledge that the loss of the Guv'nor has lead to a (temporary) drop-off in such thinking... however, the recent meeting at Sotwell reassures me that there are S7 modellers who are prepared to to offer such benefits to others. As an example:- Richard Carr was aware of our interest in JLTRT tank wagons and passed some etched axleguards our way when we met at the show.I'm considering drawing up some artwork for etching something else anyway, but I don't really want to get into the habit. I don't know how many Mk2s I'll end up building in the future!
