Falcon in 7mm from heljan and other locomotives
richard carr
Mick
Yes I think mine is sitting a little high, or the body isn't quite sitting properly on the chassis.
The other thing to bear in mind is the differing colours and lack of weathering do effect how they appear.
I'm still pleased with it and for £500 they are a relative bargin compared to a JLTRT kit.
richard carr
Mick
The other thing I was going to ask is when were the 40's air braked because my green heljan 40 has a red train air brake pipe which I don't think is correct, or did they get air brakes when still in green ?
Richard, oh my, brakes :eek: mine field here, many were dual braked from the mid 60s, but not all of the class were dual braked, some remained vacuum braked to the very end. Some locos were dual braked and then in the last years reverted back to vacuum only.
So yes, you can have an air braked green with small yellow panel and pre tops numbers, in 1970 there were 85 dual braked locos, in 73 there were 120, but not necessarily the same from 71 unless they are typos. By 1980 it had risen to 123 and that's probably near the maximum ever achieved as they were on the run down by then.
Do you have a rough date or numbers you want, I can check them off, a quick scan through the digital collection shows D213 with small yellow panel at Kingmoor as late as 1968, but there's full yellow panel locos as early as 66-67, your best bet is one from the 1970 list, I'm afraid I don't have dates for dual brake fitting, though I suspect it must be out there somewhere;)
Mick
Richard, don't get me wrong, it's a very nice model (Heljan) as are many of their others, however the discrepancies are deal breakers for me, as is the Deltic tumblehome and nose shape. Having said that I have their class 26 and I'm sure there are bits not quite right there too, but oddly I'm prepared to accept that on a 26 but not a 40 or 55 :confused:.
Dual standards or what LOL
SteadyRed
Pugsley
I don't think it's got anything to do with Babar - it's wearing a hat and looks to be of a different style. There is one in Babar that wears a hat, but the hat is of a different style and it wears something a bit like a sailors outfit.
The shorts are definitely blue:
http://www.class47.co.uk/c47_zoom_v2.php?img=0770050084210
and it appears from the very top left, that the hat is the same colour. The jumper is definitely striped and jumper base colour isn't white, for two reasons. One is that the jumper is no brighter than the elephant colour, which is definitely grey and secondly, the outer edge of the sticker is white, and the jumper is darker than that. It could be yellow, or pink, possibly light blue.
I reckon a pale yellow base, with pink or green stripes wouldn't look out of place. Whatever happens, you can guarantee that a colour picture of the elephant will turn up after you've finished the model!
In terms of size, it appears to be about the same height as the cast Falcon - you could then calculate the approximate width from the black and white picture.
Brian Daniels
Fred Lewis (Welsh Wizard) of this parish says it was from a birthday card. I think you are right Pugsley, we will have to do a good guess based on that B&W which I too think it's got a bit of a striped shirt on.
OzzyO
Hello Brian,
this is about the closest that I've found,
th
th
All of the drawing that show him in blue shorts show a white tee shirt. It looks like Babar is the one in the white tee shirt we need the name of the one in the yellow tee shirt.
OzzyO.
